Thread: 240SX Belt Question
    No autobahn needed.
    Stone Mountain
    Default 240SX Belt Question
    Sup guys
    Alright I got an unorthodox underdrive crank pulley.
    What belt sizes do I use now? And if only it was that simple, but also, im running without P/S, so im thinking that theres only going to be a short belt going from the crank pulley to the water pump and thats it then the other belt for the alternator and all that. Can anyone inform me of the sizes or part numbers for this.
    Thanks in advance
    -Jon
    Push more than others think is Safe
    Expect
    more than others think is Possible
    Senior Member babowc's Avatar
    is the pully different size?..
    ka24E or DE?
    as long as the pulley isnta differnet size.. use oem belts....
    No autobahn needed.
    Stone Mountain
    Its a DE
    And yes the pulleys are differnt sizes, the unorthedox U/D pulley is smaller
    Expect
    hm..
    if its smaller.. you should really ask unorthodox.. i dont see why they made the pulley smaller.. since that would change all motor accs.'s rotation speed..
    No autobahn needed.
    Stone Mountain
    ya, its smaller i know that, it spoosed to be so theres less friction in the movemnt or something , i dont know how to explain it very well
    but they have the belt specs if you DONT have P/S, they only have it if it does, thats what im trying to figure out, what the belt specs are if you dont have P/S and only the water pump
    Expect
    Find out the stock belt length and their recommended belt length with the pulleys and subtract the difference from the stock belt with all your accessoreis and bingo.
    No autobahn needed.
    Stone Mountain
    Aight
    Thanks man
    Expect
