Results 1 to 15 of 15
Thread: what should come next?????
    flowery branch
    Default what should come next?????
    i got a 99 prelude sh and i got rims, carbon fiber hood, lowering kit, exhaust, header, intake, pulleys, intake manifold, short shifter, fuel rail, fuel pressure regulator, spark plugs and wires. and i dont know where to go next? have any ideas????
    project cccheap!!!!!
    Winder
    Help me out and let me have it...
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    Hondata or some sort of ECU.
    then coil overs
    nitrours and injectors with an upgraded fuel pump
    then get upgraded brakes, lol
    stockbridge
    turbo.
    Woodstock
    turbo.
    indeed.
    or JRSC
    Val RIP
    my only rule in life
    rockin' the double M's
    l'ville,ga
    ICE
    turbo
    turbo
    ECU cause whatever you do next, your gonna need it anyway.
    Chrome PRO ECU $180-220 from digitalboxtuning.com
    Conversion Harness $90
    Macon
    type S cams wpuld be a plus. If you want to stay N/A, I would get a set of cams of some sort, and a programmable ECU (chrome) What type of intake manifold do you have? If you have a skunk2 or Euro-R, get a ECU made to run a single plane IM. The P13 is made to run the dual plane manifold.
    Land Rover LR3 HSE
    Jan 2003
    take it to a show, dur.
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    YOu need to build you car evenly
    You have no brake or suspension upgrades to handle your engine (as puny as a honda engine may be :P)
    IMHO
    Get some coilovers or a good shock/spring combo
    As well as some vented brembo blanks and some better brake pads. I like endless personally
    IA Member USDM_SS's Avatar
    I would have to agree, suspension and brakes would be a rather smart idea.
    Macon
    Quote Originally Posted by YokotaS13
    IMHO
    Prelude's come with pretty good brakes from the factory. I had the factory Nissin rotor's and pads on my prelude for about 10k miles and never had a problem with fade, including braking 120-20 once to avoid a deer... It stops pretty quick. If you plan on auto-x'ing any, then you should probably get a set of rotors and pads get some braided lines and upgrade the brake fluid (I use Motul).
    as for the suspension, tein basics will probably be sufficient for your needs.
    Land Rover LR3 HSE
    murdahrin dem Blood-Claat!
    Quote Originally Posted by allmotoronly
    goddamnit! I got beat to it again! yes prelude breaks are wonderfull under heavy usage. Yes tein basics would probably serve it's purpose.
