Results 1 to 18 of 18
Thread: blown turbo
    paint booth
    Default blown turbo
    what does a turbo do when it needs to be rebuilt.
    UR CAR SMOKES, THE TURBO MAKES NOISE AND OR WONT BUILD BOOST. IT WILL ALSO HAVE ALT OF SHAFT PLAY
    paint booth
    smokes where
    Quote Originally Posted by boostedb16
    smokes where
    OUT OF THE EXHAUST. THAT QUESTION MEANS THAT UR CAR IS SMOKING AND UR TRYING TO FIGURE OUT WHATS WRONG WITH IT. CLOSE?
    paint booth
    no it means i have heat wrap on my down pipe and i had a oil leak and oil leaked on it and i did not know if oil was coming out of my turbo or that oil needs to burn off so this is a question about a possibly blown turbo.
    IF UR TURBO IS LEAKING OIL U WOULD SEE IT COMING FROM TTHE BOLTS OF THE EXHAUST HOUSING, OR THE FLANGE/FITTING FOR UR OIL DRAIN OR SUPPLY. IF THERES OIL OR THE SUPPLY OR DRIAN FITTINGS, CLEAN THOSE REALLY GOOD AND START UR CAR AND WATCH FOR LEAKS. BUT IF A TURBO NEEDS TO BE REBUILT IT WOULD SMOKE LIEK CRAZY OUT OF THE EXHAUST (MUFFLER).
    paint booth
    ok then my turbo should be fine, no smoke out of the pipe.
    I WOULD SAY SO. CAN U CHECK FOR UP/DWN AND IN/OUT MOVEMENT OF THE SHAFT BY GRABBING THE NUT ON THE COMPRESSOR WHEEL? IF UR CONCERN CAME FROM THE OIL ON THE DWN PIPE ID GUESS THAT THE TURBO DOES NOT NEED TO BE REBUILT.
    paint booth
    ok thanks.
    CAN U CHECK FOR UP/DWN AND IN/OUT MOVEMENT OF THE SHAFT BY GRABBING THE NUT ...
    Wow, this thread just got a little gay for me.
    paint booth
    Quote Originally Posted by PacoX
    yea when you started posting.
    The Dark Lude dakilla4ever's Avatar
    In the Darkness
    Quick question. Can you pass emmisions after you turbo your car? Any info on this would be helpful.
    paint booth
    dont know but thats a good question.
    Tech Fanatic
    warner robins
    Quote Originally Posted by dakilla4ever
    I dont know how it is up where you live, but make sure you don't have any check engine lights on if thats how they test yours. Also make sure your idle and cruise (no boost) are tuned for a 14.7 a/f ratio. As long as your car is making a clean burn, you should be alright.
    //M5 Killer morris's Avatar
    Snellville
    I passed with mine being turboed in April
    noob?call it transfer
    Bama
    what color would the smoke be mine is pouring grey smoke . i think the motor is toast.
    Some people are like slinkies!good for nuthin but u cant help but smile if you see one tumble down the stairs
    Factory Intgegra Type R LSD $300 PM Me.
    Snellville
    smoke from Oil would be blue.
    Smoke from water ie bhg would be white
    Bama
    it would be acktin up like a readheaded stepchild i think i dunno
