Thread: need help!!!!
    Certified Gearhead MrEG62U's Avatar
    D'ville
    Default need help!!!!
    me and a buddy of mine have been working on his ls/vtec build. we are using a type r tranny, the starter and the half shaft that we have from the ls dont fit. is the starter and half shaft different for the type r then whats used on the ls???
    posted by 01dc2 jdm
    its just a vtack engine.
    Gainesville
    sure is....
    Halfshaft might be from an AUTOMATIC, then the bolt pattern is different.
    If it wont slide in the tranny, then if hes using a HYDRO tranny with a CABLE TRANNY halfshaft, you MUST switch the AXLE seals out. IE
    Hydro Tranny with HYDRO Halfshaft
    Hydro Tranny with Cable Halfshaft and Cable Tranny axle seals
    Cable Tranny with Hydro Halfshaft and Hydro Axle seals
    if you dont have the right combo, then the shaft will only slide in with about .5in left an you wont be able to get it in an bolt it to the block
    D'ville
    thanks
    posted by 01dc2 jdm
    if u have a type r tranny use type r tranny parts it is that simple
    WEST_SIDE
    Quote Originally Posted by harper22
    not necessary,
    WEST_SIDE
    Quote Originally Posted by Mr. Vteckidd
    i just learned somthing new today ,
    _ernie
