Results 1 to 21 of 21
Thread: bike keeps dying!
    still searching! Hondatwin23's Avatar
    Atlanta\Lithonia
    Default bike keeps dying!
    i have a 2000 gsxr 750 and yesterdat while riding the bike goes totally dead and wont start.i had a friend bring me a fresh battery and by the time i get home its dead again and when we tried to use the replacemment battery on another bike it didnt work.
    anyone have this kinda problem and how was it fixed because its the perfect temp outside to be riding
    http://twitter.com/LEGEND_STATUS
    1997 w/1999 civic w/ Built GSR...FS/FT
    OLDSCHOOLRULEZ
    Gainesville, lawrenceville
    is the fi light on? or led indicator? if not pull the tail section and check the regulator assembly. check the connector to see if it is melted same thing happened to my 98 i had to correctly rewire the connection.
    IF IGNORANCE IS BLISS, THERE ARE MANY HAPPY PEOPLE OUT THERE
    Johns Creek
    Either the stator or the regulator is likely dead. Start with checking the regulator like stated in the previous post.
    Atlanta\Lithonia
    no lights are on. its just dead i cant get nothing to go on. i jusmped it with my car and it ran until i took the cables off and it died again
    Have you tried adjusting your idle?
    Johns Creek
    Check your battery connections. Also, get a multimeter and post your voltage readings with the bike off, in run, and while attempting to start.
    Atlanta\Lithonia
    it idles fine when its running it just that it seems to be running directly off of the battery and killing it.
    can i get a proper reading if the battery is really weak
    OLDSCHOOLRULEZ
    Quote Originally Posted by luthi
    DID YOU CHECK THESE ITEMS?
    Atlanta\Lithonia
    i check under the tail and it had a little grey dust underneath there but nothing i saw was melted. No lights on the dash is on the bike is totally dead
    Atlanta\Lithonia
    here is a picture of what she looks like !
    Attached Thumbnails Attached Thumbnails -14992944_54060521_0-jpg
    Johns Creek
    Get a MM. Post your voltages. Or take it to a shop and spend some money to fix it.
    <3 boost
    welcome, NC
    Quote Originally Posted by Hondatwin23
    that pic helps out so much.....
    93 turbo mr2
    99 buell S3
    Sounds like the voltage regulator to me too. Besides the regulator being bad, you've probably also blown a few fuses in it.
    Atlanta\Lithonia
    i checked all the fuses that i could find they were all still good. how much would the regulator run me
    A day late, a buck short BufordŽ's Avatar
    Apr 2003
    Starin' at the world through my rear-view.
    My guesstimation would be to check the stator. Good luck with it, buddy.
    My 2001 Acura 3.2CL Type-S
    Val for president!
    Yes, I would have voted for her.
    In loving memory of Valerie Antranikian.
    Atlanta\Lithonia
    with the stator once it goes bad the bike shouldnt be able to start again?
    i charged the battery a good bit yesterday and it started fine then i left if for a couple of hours and and it started fine again without the dash going dim
    Atlanta\Lithonia
    ITS OFFICAL ...............THE STATOR IS DEAD!!
    JDM TYTE AnthonyF's Avatar
    Probably b/c you're an idiot.
    -Ant.
    The Carbon Fibered R6
    Quote Originally Posted by David88vert
    Atlanta\Lithonia
    mmmmmmmmmmmmmm fixed years ago!
    lolol
