Results 1 to 13 of 13
Thread: In need of ignition help. Nissan 240sx.
    USAF Security Force Cato ED-6's Avatar
    Acworth & Woodstock area
    Default In need of ignition help. Nissan 240sx.
    ***We fixed the problem. This thread can be deleted or whatever. Thanks for the help.***
    Gainesville
    what exactly do you mean it jsut turns?? like when he turns the key nothing happens period?? need more info...
    He can turn the key, just nothing happens when he does. The engine doesn't even turn over. The car is in perfect running condition, except for this problem. We just checked the battery and its fine. Still have no idea whats going on.
    WEST_SIDE
    check if your starter is getting power, bang it a lil not to hard though
    Starter:
    Ya just checked that, starter is fine. Connected it straight to the battery, worked fine. Thanks anyway.
    WEST_SIDE
    im not sure if you have a relay between the starter and ignition , fuse,
    BTW those the instrument cluster light up ?
    -Ernie
    WEST_SIDE
    Quote Originally Posted by Lord Canti
    Starter:
    so the engine cranked over?
    Quote Originally Posted by SLow_POke
    No, the starter works. But the engine is still down. sorry about the confusion.
    And he says the cluster light was broken a while ago. but that shouldn't change anything, Right?
    WEST_SIDE
    no but just wanted to know if you where getting power to the ignition switch. when you positiont he starter tothe "ON" position
    Gainesville
    yeah i would make sure all the relays and fuses are good...then he might have to replace the ignition switch itself..you know the part you put the key in and turn..lol
    Gainesville
    btw slow poke hit me back...
    Called our friend, told him what was what and he said the switch was the only thing we hadn't tried. So a hour later and its being fixed and all is well. Thanks for the tips and I just read the posts and damn man, Street Speed you called it.
    Gainesville
    no problem man lol i had that problem one time cept we were like 200 miles from home i hot wired that bitch jsut so we could make it back, lol...
