Thread: boost on chrome pro
    West palm beach
    Default boost on chrome pro
    how much can i boost useing chrome?
    do i need to change the map sensor ?
    where can i get said map sensor?
    damn i posted in the wrong section again...can someone move this to forced induction please..............
    boost amount depends on alot of things, with a stock map sensor you can boost 13~14psi or so, and more depending on if you upgrade to a 2bar , 2.5bar map sensor etc. you will also need other supporting modifications like upgraded injectors, etc.
    1.7 bar (stock)=11ish psi
    2.5 bar (motorolla)=22ish psi
    3 bar (gm)=28ish psi
    stock block--stick w/ stock mapsensor, but better have larger injectors and tuning. aftermarket mapsensor--better have built bottom end at least, much larger injectors, and tuning.
    West palm beach
    looking to boost around 12-16 lbs with built bottom end and injectors ect,trying to keep it simple and go with chrome.just didn't know what chrome could handle and where to get the map.............
    get a gm 3 bar. you can order them from gm dealership or from autozone/pepboys. mapsensor for turbo transams or you can get it from aem too.
    or, go to www.gmpartsdirect.com and enter part number 12223861
    get the wiring harness that goes to it for ease of connection and don't cut off the stock map sensor plug. just splice the 3 bar into the stock wiring and leave the stock mapsensor disconnected.
    3 bar works fine as long as you scale the map and tune it properly up to 28ish psi so you'll be fine.
    Ive got crome pro
    Scotty tuned it and did one hell of a job, thanks again man
    -TAylor
    Lexus GS300
