Thread: 3sgte power problems
    S N a p p e r SNapper's Avatar
    Lawrenceville, Georgia
    Default 3sgte power problems
    ok i've been having this problem for a while now with my 3sgte swap in my 1990 celica. basically i'm getting hesitation and general power loss. here are the facts
    this is a turbo 2.0L toyota motor, same as mr2 turbo.
    in high rpm's it starts hesitating and breaking up.
    my friend said he saw a little blue flame coming out the exhaust while i was floored the other day.
    sometimes when i start it black crap spits out of the exhaust all over the ground but not always.
    the turbo is running at about 14 psi but the problems occur at stock boost also.
    it starts instantly when it's cold but can take up to 4 seconds to start when it's hot.
    i've changed the spark plugs, distributor cap, rotor, ignitor, ignition coil. the plug wires are fine.
    it doesn't seem to smoke when i'm floored.
    it's running a blitz access ecu that came with the celica gt4 clip from japan. something with the ecu could be the problem.
    60-90 kph roll on's have been timed at 1.9 seconds when it ran correctly on the blitz ecu. now it runs anywhere from 2.1 to 2.5, usually 2.3 to 2.5 but sometimes it will pull a 2.1.
    the hesitation can be very obvious at times and it's like i'm just letting off half the throttle kind of. when the problem first started it wouldn't even rev past like 6 rpm very well.
    the boost pressure doesn't drop down suddenly or anything
    if anyone can offer any help on this let me know. i've been trying to fix this like everyday and i can't find the problem.
    2006 R1 with stuff on it
    ok so i was checking out the o2 sensor and if i unplug it and monitor the voltage it's showing me correct but when i check out the voltage on the wire running the ecu it's showing 0.05 to 0.06 when it should be showing 0.5. so when i plug the o2 sensor in it's just showing 0.05 to 0.06 still when it should be bouncing up and down. it's like it's shorting to a ground but when i unplug the wire from the ecu and from the o2 sensor so that it's not plugged into anything, it's not grounded. i tested it for ohms. so WTF.
    Southern Car Customs, Inc
    I am George Meyers owner of Southern Car Customs Inc in Savannah and we have a motor guy by the name of Doctor Tweak who specializes in Toyota's I will forward him a link to this posting and see if we can help you.....
    Thanks
    George
    www.GetSwapped.com
    www.SouthernCarCustoms.com
    www.SCCAUTOFEST.com
    You know Drew, you ought to just come over to my shop and we'll swap the ECU out with another one, see if that Blitz ECU is causing the problem.
    Sorry I didn't get back to your chat the other day, I was up to my neck in custom a/c lines
    -Doc
    man it's like a 4 hour trip down there. right now i'm trying to find brake pads for my car then i gotta replace my headgasket and then maybe i can head down there for a vacation and get this thing fixed up.
    <3 boost
    welcome, NC
    got a stock BPV or aftermarket BOV?
    i get hesitation on mine in the upper rpms and its due to my apex BOV
    93 turbo mr2
    99 buell S3
    it's stock
    GT-FOUR
    Gainesville, GA
    i think dr tweak has a point with the ecu,
    post up on alltrac.net and see if anybody there has an ecu
    90 celica GT-FOUR
    Insanely Crazy
    Loganville GA
    have you replace the coolant temperature sensor? Your sensor might be bad, causing it to run on limp mode. When you engine is not in an operating temperature, your ecu will retard the timing..preventing it from messing up. Thats the same sympton i have on my mr2. Problem is fix now.
