Thread: Ls swap in ek help...
    Straight O.G. BlackEj6's Avatar
    StockBridge
    Default Ls swap in ek help...
    I have a 95 Ls Motor(B18B1).I will be puttin this motor in my 97 Civic Coupe dx non-vtec(OBD2)Can some one let me know what type of dizzy to get and all of the other parts i need.ECU,Altenator,Intake Mani..I heard i cand just get an OBD2 -0BD1 conversion harness and save alot of time and money..Let me know IA..
    West Staines
    if your using your old harness just get an OBD2 Dizzy and Alternator (i believe you should be fine with that IM, if by chance you need an OBD2 IM though i got one i can trade you for.) and use an OBD2 ECU and you should be good to go.
    WEST_SIDE
    Quote Originally Posted by BlackEj6
    00 Civic Si Rear mount,
    might need some wiring harness modification(extending )?
    convertion harnes OBD2-> OBD1
    -Ernie
    BTW do u have the complete hareness with it ? including sub harness?
    Banned typerek's Avatar
    buford
    si mounts, obd1 conversion, integra harness, integra dizzy.
    StockBridge
    Quote Originally Posted by smoke_Em
    -Ernie
    Ill find out.Whats the Sub Harness?
    WEST_SIDE
    the half of the harness that connects THE MAIN ENGINE harness to the ecu located on the passenger strut tower enginebay goes thru firewall to connect to the ecu , but it cool if you dont have it
    i also forgot to mention the motor mounts for the swap
    -Ernie
