Results 1 to 11 of 11
Thread: how can i hook up dvd player in my civic
    Default how can i hook up dvd player in my civic
    i have a dvd in my car put i dont know how to connect the foot brack & hand brack wire for the dvd play when i driving at the same time can you guys help me with that
    I JUST DONT GIVE A FUK dereksi's Avatar
    Pull up that console where the arm rest is and find the ground wire screwed into the handbrake,find another ground and wire that to a switch to turn on and off. Thats what i did with mine. I can do it for you just pm me and let me know. It took me about 15 mins to do in mine.
    but i have 2 wire that hand brake wire and the foot brake wire
    I'm guessing you want it to play while driving...
    Quote Originally Posted by dereksi
    no need to do anything with the brake or anything else, simply jump the wires from the screen's control unit.
    is the foot brake wire ground or positive if its positive hook it up to your switched power and the other the same way just make sure you know if its positive or not. the brake wire will be by the peddel attached to your brake light switch probably.
    no but the thing is i have two different wires in my dvd 1 is foot brake and the other is hand bracke wire and i want it to play while i driving so can you guys help me is an Alpine iva-d300
    Quote Originally Posted by bluecivic
    i can't remember how mine went but it's either positive or negative that goes to them...I would try grounding both of them first. You DON'T have to run them to the brake(s), simply find a ground or positive from one of the other wires... you should be able to download a manual for it off of alpine's website.
    go here http://www.stylestandard.net/oswego/...%5D&component=
    download the manual if you dont have it or look on the sticker on top of the player and see weather the wires are ground or positive and then hook it up to either a ground or positive. no rocket science involved im just too lazy to download the manual to tell you.
    Dec 2003
    Alpharetta
    you need two switches, the foot brake sees a positive input and the handbrake sees a negative. its easy. just hide the swithces somewhere. kinda sucks but youll have to run through the little sequence everytime you want to use the screen, still no big deal.
    Vroom Vroom
    Quote Originally Posted by AlexHerb
    why bother switching them at all? Just wire them straight and it's always on...
    MROZ10
    You have to use switches because the Alpines want to see an "alteration" in current. If you just wire them straight, it will not work. Some indash screens only need to see ground on the brake wire. A simple toggle to ground will accomplish this. Alpine has two wires....yellow w/ blue and yellow w/ black. You can do one of two things. 1) Bypass with two switches. By doing this you wil be able to watch video and access features without having ebrake pulled. 2) Buy bypass adaptor. You can get them online, ebay and such. Pm me and I will tell you how to do the 2 switch wiring. You will only have to hit the switches once per start of the vehicle. Then you can toggle your "video" on and off if you are in a situation were you need the video not to be able to play.
