Thread: p0505, p1259!?
    Integra KA98S10's Avatar
    Default p0505, p1259!?
    well i was driving home hit 4500 and shook bad.. i hooked up my scanner and got these codes.. my CEL has been on ever since i got my engine rebuilt, but its because they dissconnected the unimportant sensors. I know the p1259 is vetc malfunction, but why would this come on? my oil level is fine and the coolant is full.. any suggestions?
    WEST_SIDE
    Quote Originally Posted by KA98S10
    al sensor are there for a reaon .IMO u need them unless you eliminate them with a tune or when u burn a chip for your car .
    and i seen the p0505 i think its the IACV
    could be that thats disconnected or went bad . i.ve also seen a major vaccum leak throw this code
    WEST_SIDE
    i just re-read your post .does it rev past 4500?
    yeah peter @ ISP built it and he always by-passes the IACV, but this is the first time this code was thrown. usually its another idle code.. i was gonna hook it back up, but half of its missing.. Oh and if this makes a difference my motor was just broken in and i've hit vtec like 10 times now.. This sucks!!
    Quote Originally Posted by smoke_Em
    nope.. like the fuel is being cut-off
    WEST_SIDE
    i would try hooking back up . i knwo you can bypass the coolant but i think you still have to have it pluged in . try plugging it in . or take it back to the shop that put it together im sure they will be happy to help you .
    maybe ur vtec MIL is a brake in the wire . ? or solenoid went bad. .? try cleaning it might have little metal shaving from the rebuilt .
    like i also mentioned a major vaccum leak might also throw that MIL ,IACV.
    WEST_SIDE
    MAP sensor also ? i could be wrong , but try unplugging it will its idleling see if you notice a difference .
    MAP might be seen to much manifold pressure .
    cutting it off at 4500 .
    im jsut throwing ideas at u hope it helps
    Thanks for the help!! im gonna look at my vac lines tomorrow.. hopefully that all it is..
    WEST_SIDE
    NP . it sounds liek a easy fix just have to trouble shot some
