Results 1 to 5 of 5
Thread: HELP WITH SR5 corolla
    IAs Resident Pot head
    Default HELP WITH SR5 corolla
    OK I just got a sr5 corolla, it ran great for 3 days now it has a dead spot in the throttle between 1/8 and half throttle. 4ac engine, brand new spark plugs, wires, cap and rotor.
    cant find a vacuum leak anywhere, HELP!!!!
    WEST_SIDE
    Lightbulb
    tps? maybe thats what it sounds liek .probe it with a volt meter .key on engine off and open ur throttle slowy pas the dead spot then slowy back to close . u should get
    throttle close around .5 volts
    fully open just bellow 5 volts
    and in between should gradually go up to 5 volts..
    see if you has an actual dead spot
    hope
    this helps
    Alpharetta
    Default CARB
    On the 4ac engine the carb likes to go bad so get a rebuild kit or a new carb from weber performance...or maybe the vacum lines are wrong but i would be happy to take a look at it!! ive got the same car so give me a shout back
    Peace..JP
    DUNCANMOTORSPORTS.COM
    Unknown
    It might be your vacume advanced on distributor, that wears out.
    Super Dave Z U L8R's Avatar
    Roswell
    clean out your carb, definately sounds like a carb primary fuel problem
