Results 1 to 13 of 13
Thread: Tire size for a 15x8 wheel.
    Kennesaw, Ga
    Default Tire size for a 15x8 wheel.
    I'm about to order some 15x8 wheels and need to know what size tires I should get. They'll be used for drifting just FYI. Thanks.
    Drifter/Kneedragger
    Buford, GA, USA
    you can fit anywhere from a 195 up to a 225 or so.
    Kennesaw, Ga
    These are going to be tough to come by, aren't they?
    110!!!! Nopaintsls's Avatar
    some where near YOU!!!
    for drifting... I'd go with the stretch 195/50 make it easier to spin
    Woodstock
    205/50/15 possibly...
    Val RIP
    my only rule in life
    The guys that posted above me are gay, for giving wrong information. How the hell you gon' fit 195 on an 8" rim, don't be gay & stupid. The widest a 195 will stretch is from 5.5-7". 215 is from 6-7.5". So you would need a 225 or wider tire, 6-8".
    8 inches wide is quite large, especially for a 15. I mean a 225 is stretched at that width. probably gonna be some trial and error. see what the AE86 guys are doin. should give you a good idea.
    Certified Gearhead Z28's Avatar
    For what it helps: I run a 255 on my 16x8 stock wheels. Original owner had 235 on them.
    decatur
    Quote Originally Posted by KevinT707
    beat me to it
    decatur
    i would go with 225. (215 at least)
    Drifter/Kneedragger
    Buford, GA, USA
    a 195 in a 15" with the big floppy sidewalls will pretty easily stretch on an 8" wheel. i run 215's on my 8.5" fronts and they barely stretch. the stretch will help with stability on the tires for drifting. of course this all depends on the car, because a 195 rear doesn't yield much grip so it'll slide TOO easy if you want to drift with some speed.
    Kennesaw, Ga
    Quote Originally Posted by wantboost
    That's what I went with. Kumho ECSTA AST's in a 225/50/15 all the way around. Thanks for the input guys.
    Quote Originally Posted by HiPSI
    Weird I've never heard of tires being able to stretch that much to fit wider wheels .. I guess that only works when it has a big sidewall as you stated.
