Results 1 to 25 of 25
Thread: TW: 1994 civic vx turbo gsr swap
    middle ga
    Default TW: 1994 civic vx turbo gsr swap
    vin: 2hgeh237xrh500163
    block code: 2311856
    i would have to get some pics...and i dont have a camera. its a green 94 vx hatch. body has 180,000 i think...motor has ~115k. here are some specs:
    engine and trans:
    95 gsr motor
    95 gsr trans
    hasport mounts
    blox intake manifold
    edelbrock 65mm throttle body
    rc 550cc injectors
    prostreet lightened flywheel
    act extreme pressure plate and clutch
    drag gen III turbo kit (57 trim / .63 a/r)
    f.a.s.t. oil return line
    walbro 255lph fuel pump
    b&m fpr
    b&m fuel pressure guage
    msd blaster ss coil
    msd mod cap
    msd wires
    msd 6al ignition
    chipped p28 tuned at mainstream 260whp/180lb-ft @ 7psi
    still has a/c and heat a/c is retained by way of a crv a/c bracket.
    2.5inch tsudo exhaust
    no cat!!! i cant say it will pass emissions!!!!!
    o2 bung welded in down pipe for wideband..in addition to the bung for your stock o2 sensor.
    new honda timing belt and honda waterpump at 100k right before i swapped the motor in. also changed the intake manifold gasket with a oem honda gasket at the time of the swap. brand new honda clutch master cyl. and also new cv shafts at the time of the swap. and a new type r throttle cable.
    interior:
    tan cloth integra seats in the front
    black cloth civic seats in the rear
    black carpet
    triple guage pod w/boost, water temp and oil pressure guages by autometer , water temp and oil press. guage not hooked up at the moment
    apexi pen style turbo timer
    kenwood cd player
    lightning audio 5 1/4" speakers
    the guage cluster came from hong kong. reads in mph 9k tach, 145mph speedo. all amber lights.
    golf ball shift knob
    exterior:
    stock hood, wing, fenders, bumpers ect. i dont rice my shit out.
    15" flik blasts (flat black)....they are just like rota slips. they are the knock offs of the knock offs of the knock offs of the knock offs...you get what im saying
    all 4 tires are falken ziex 512s 195/50/15
    stock shocks
    nuespeed race springs
    also have 2 extra flik blasts (also flat black) with 2 205/50/15 bfg drag radials....only about 9 passes on them.
    car gets 30mpg constantly. heat blows hot, a/c bows cold and it is reliable. i also have a 10 psi wastegate spring that i have never used in it that can be included.
    the bad:
    the clear coat is peeling on the fender and roof
    passenger door does not match the rest of the car..the clear coat is clouded and there is no lock cylinder for the key...door does lock though!
    driver door came off of a dx..the side molding has been removed so there is holes in the door (for the side molding to attach to)
    car has the usuall scratches for a 12 year old car.
    no major body damage just little dings here and there..mainly on the hood where the wastegate dented it.
    has solid mounts so there is some vibration...i dont mind it but others might.
    over all the car is pretty solid. it runs good, gets good gas mileage and is paid for! i know you are gonna ask what kinda times has it ran so:
    best was [email protected] on street tires and full interior @ 7 psi also ran once on drag radials..the track was so horribly horrible ( SDR ) 13.1@106 with a 2.3 60FT. ill try to get some pics. i may have forgotten some little things but im just trying to get an idea about what it may be worth.
    the mods of this site want a price to be listed even though im just guaging interest and do not know what to ask for this. therefore im selling it for $11ty,000,000,000...OBO i will negotioate alot! the pics are old...the car has a green bumper now. you can also see the miscolored paint on the passenger side of the car
    Attached Thumbnails Attached Thumbnails -turbogsr-jpg   -turbogsr2-jpg   -turbogsr3-jpg
