Thread: Clutch
    Senior Member BlkCD5's Avatar
    Default Clutch
    Well, since my throwout bearing is going bad, I might as well replace the clutch. So, currently im looking for a stage 1 clutch and possibly a flywheel also. What would you all recommend me getting? Which companies should I go for and which should i avoid?
    WHEREMYBITCHES dowhatido's Avatar
    lost
    COMPETETION CLUTCH, THEY HAVE ALL THE CLUTCHES YOU WILL NEED AND PACKAGES WITH FLYWHEELS. I PERSONALY WOULDNT GET A FLYWHEEL, I WOULD JUST HAVE YOUR STOCK ONE SHAVED, YOU GET SOME VIBRATION WITH THE ALUM ONES
    bong rips prefered!
    RIP 94 ej1/b18c1
    welcome rebirth of 93 eg/b18c1
    Finally a reply, thanks man. I don't think i would consider shaving mine since I've heard that the flywheel could fail and crack.
    Boosted 4door
    i have an exedy stage 1 in my car, works great...doesnt slip at all and my motor is pushing 240 ft lbs of torque to the wheels. i think i have about 20k miles on it now.
    bought it for $260 shipped from clutchcityonline.com
    Do you have a lighter flywheel with that clutch?
    WEST_SIDE
    IMo i wouldnt lighten it ive had both and even thought i like the faster revs from lighten . i preffere anythign close to oem . also heard u get chattering . from lighten flyswheels .
    Spooned Sports
    woodstcok, GA
    exedy stage 1 clutch and ACT lightweight flywheel
    Enter the dark side! rocket256's Avatar
    Racer Ave. Ga.
    I got a Clutch Net Stage two and its great. Its softer then stock but grabs like a vise!
    95' Civic Hybrid GSR-T
    *462hp/ 282tq!*
    (Boost is like sex. :idb: "It's no big deal unless your not getting ANY!!!"
    Boost is an addiction! ! ! )
    Oviedo, FL
    I use Clutch Master for my Civic which works like a charm along with my nitrous. For my RX-7's I have a HKS twin plate kit on one and a OS Engineering twin plate on the other, both work perfectly and I love the jingle!
