Results 1 to 3 of 3
Thread: 99/00 Civic Si Read Disc Conversion into 99 EX Checklist
    IA Senior Member CiVeK9's Avatar
    Default 99/00 Civic Si Read Disc Conversion into 99 EX Checklist
    I've been looking everywhere for a guide or checklist of everything i need off a 99-00 Civic Si to complete a rear disc conversion on my 1999 Honda Civic Ex Coupe..so far no luck..if anyone can post a link to one maybe from Honda-Tech or something it would be greatly appreciated.
    I am getting the kit locally for a good price and it comes with the following
    below is a list of everything that comes with it. No Brake lines and its missing a bracket...is it worth getting steel braided lines or stick with oem? if i am missing anything else please list
    Check List
    control arms
    hub assemblys
    calipers
    oem rotors
    e-brake cables
    Missing
    it is missing one braket that attaches the caliper to the brake line.
    how much does this bracket usually run?
    brake lines
    I believe i need a 99-00 SI Proportioning valve
    found it on honda-tech..thanks anyways!
    http://www.honda-tech.com/zerothread?id=1513752
    you would also need the brake porportoining valve from an si other than that you have everything you need
