Results 1 to 11 of 11
Thread: 2 questions
    Gwinnett-Grayson
    Default 2 questions
    ok, there are two things with my car that im concerned about. my car when i start it up after it sitting for a while will idle at 2k for a a while, i know it usually does this in cold weather and not in warm weather, but it still idles at 2k when i start it up after it sitting for a few hours and what not. The second question is about my car starting up, recently i will turn the key and it turns over, but it will shut off after a few seconds or not even a second. i dont know know what it could be, someone please let me know!
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    My Spoon Is Too Big! Flip's Avatar
    For the running at 2k thing that is pretty normal even in warm weather. The temperature outside is still relatively cold compared to the temp that your engine runs at.
    As far as the shutting off thing do you have an after market alarm system installed?
    Gwinnett-Grayson
    no, i think the previous owner used to have on on it, but from what i remmeber he said he disabled it. but yeah i dont could it be maybe spark plugs or the starter or something
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Quote Originally Posted by blacknightteg
    If there was an alarm and it was uninstalled/disabled i woudl put my money on that. Get someone that does alarms to check the connections and pull the alarm out or while you're at it just have them install a good alarm in its place while you have the connections ready...
    prelude ur ass
    duluth
    when you turn the key to start it and give it some gas does the whole car shake trying to turn after it dies after starting normally?? if so thats what problem i have with my car and its the distributors gone bad just saying there might be no spark in the plugs
    Some guy. CSquared's Avatar
    The starting problem sounds like a fuel issue to me. Cold start injector?
    My car does something similar on startup from how you've described it...
    For me it is a fuel vsv, which acts to maintain proper fuel pressure during starting and idle.
    Quote Originally Posted by 2.2L
    i severely doubt that.
    Gwinnett-Grayson
    Quote Originally Posted by CRAMERIZKING
    hmm if that is the case it sounds like that could be the cause of both the problems or something
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    eh, the vsv would be likely to cause a low lumpy idle. I've had mine bypassed for over a year now and it makes no real difference in the cars operation while it's running aside from the rpm dropping real low and climbing back up when you stop at a light.
    I tell this to everybody... if you don't know... bring it to a friend or mechanic that does. Most mechanics will give you a free estimate as far as what the problem is. The local shops used to hate me because I always took the free checkups and fixed the car on my own.
    Diagnostic tools are a godsend.
    Gwinnett-Grayson
    haha yeah, i think im gunna take it up to a shop on friday or something when i have a free day and see wtf is up with it
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Here and there Hulud's Avatar
    Omnipresent
    try adjusting your throttle cable
    Val for President
