Results 1 to 14 of 14
Thread: dropping the car ..
    where do you live ??
    Default dropping the car ..
    ok my friend has a 03 maxima ..
    he wants to drop his car ..
    so i was wondering where he can get his car dropped at ..
    would it be ok to use his stock or would after market be better ..
    thanks in advance ..
    NY STAY HIGH !!!
    S N a p p e r SNapper's Avatar
    Lawrenceville, Georgia
    stock what?
    2006 R1 with stuff on it
    what ever stock shocks or spring he has on his car ..
    would it matter if he uses his stock shock or spring if he gets his car lowered ??
    or would it be better to get some after market items then lower his car ..
    NY STAY HIGH !!!
    Hampton, Ga
    you can use them lowering it will probally blow his stock struts quick though
    Devin 5thgcelica's Avatar
    snellville
    yeah, id buy new everything. it'll ride better... and its not really hard to do yourself...
    just make sure you get the spring compression tool from the local auto store.
    ok thanks everyone ..
    NY STAY HIGH !!!
    i wouldnt wanna do it myself and mess up ..
    NY STAY HIGH !!!
    i am jill's nipple. fight club's Avatar
    Gwinnett ftw!
    you dont need a spring compressor if your putting on lowering springs, ive done 3 cars without it.
    When I was a child, I used to talk as a child, think as a child, reason as a child; when I became a man, I put aside childish things.
    whats a good lowering kit ??
    NY STAY HIGH !!!
    lawrenceville
    Quote Originally Posted by cherry kool aid
    it depends on the car and the suspension it uses like if it has mcpherson struts and all
    Macon
    Quote Originally Posted by Wurm
    haha ricers world wide slam their cars out and still use stock struts... they wont wear out quick, they will just wear out faster than normal... you might get 50k miles out of them instead of 60k.... that is unless you are being super ricetastic and cut 3 or 4 coils out of your springs and drop it 6"... then no matter what kind of struts you get, they are not going to last as long.
    Land Rover LR3 HSE
    Macon
    Quote Originally Posted by nolimitsteveo
    by lowering kit do you mean springs, coilovers, or full coilovers... also are you planning to do it right and use a camber adj. system? I recommend Eibach pro kit if you want to drop it less than 1.5-1.7", Neuspeed race springs for 2.0-2.5" and cleap ebay springs if you want it so low that the front end will scoop shit up off of the ground. If you want cheap sleeve coilovers, dont waste your time... every time you raise or lower the car, you need to get it alligned. IF you want true coilovers, I recommend Tein Basic's or Tokico Illumina Coilovers, both of which replace the spring and strut, so you knock out two birds with one stone, and they are easier to install. no spring compressor needed since you take the stock spring/strut out while it is still together, and put the new coilovers back it place.
    Land Rover LR3 HSE
    Senior Member BlkCD5's Avatar
    Nice to see someone actually modding 02+ maxima's
    yea thats what i was gunna tell my friend to go for eibach kit chamber and spring and what ever else needed ..
    a 1.5 drop would be good right now hes trying to get some new shoes and make it a sleeper ..
    but its up to him on that thanks for the info everyone ..
    NY STAY HIGH !!!
