Results 1 to 19 of 19
Thread: Question about T25.
    YOUR MOM GOES TO COLLEGE Curbow_USMC's Avatar
    Augusta
    Question Question about T25.
    this might be a dumb question but i am just wondering if a T25 from a SR20 spools/reaches max boost any slower than a DSM T25? like i said this might be a dumb question but I'm a total noob when it comes to turbo's.
    \/\/ Click pic for more pix of my ride
    I believe the sr20 t25 is bigger than the dsm t25. So it should spool a little later than the dsm, but it shouldnt be a huge difference and will still spool quickly.
    Augusta
    i just trying to find out if i want to use my DSM T25. i can get my hands on a SR20 one that is why i am asking.
    I want something that is still small but dont run out of boost before i hit redline. (i'm only gonna be running about 7-8psi)
    it will maintain boost until your redline. dsm t25 and nissan t25 have different flanges.
    Augusta
    So your happy with your T25? And what kind of #'s are you putting down?
    on the sr the t25 runs outta breath just north of about 6800rpm, thats where it stops pulling hard. between about 2800rpm and 6500rpm it a great little turbo. the t28 has a bit more huff but needs another 100rpm to kick in, of the 2 id recommend the t28.
    the dsm t25 on a d-series is to small for me. im in the process of upgrading as we speak. it pulls real good around 3k-5700 but loses steam past that.
    Certified Gearhead miro_gt's Avatar
    you can fix the fall at the end by using a boost controller that allows boost -RPM correction, such as the E-01 programmer for EManage
    but yea, expect falls of about 1psi for your boost levels
    on the sr theres nothing up there anyway cause the torque peak is way back at 5500rpm, on a stock motor.
    20 side of thangs
    i know for a fact on my friends 99 gst his t25 wouldnt be worth a poot after 5k
    Augusta
    Quote Originally Posted by miro_gt
    So with a boost controler i can make the boost last longer? amybe up to 7k or at least close?
    Toyota Tech
    Dec 2003
    Claxton, GA
    dsm t25 wont bolt up to sr will it? not sure but i know evo turbo are twin scroll, not sure about older dsm. just something to make sure of before u buy one. and yea sr factory motor kinda pointless to go past redline, its a tq void up there.
    2010 Scion xB
    im tryin to figure that out now. the big 28 off a dsm has the same trim level as a gtir t28, which is almost as good as the potato
    NO!!! read my post. the DSM t25 and nissan t25 have DIFFERENT FLANGES!!
    btw, a rpm dependant boost controller with a t25 seems like a stupid idea to me because the boost controller would cost more than the difference in the price of a turbo that can flow in high rpms and your t25!
    its not that your turbo cant hold the boost, a t25 will easily hold 7psi until redline. its that it doesnt flow enough CFMs in high rpms to feel like it keeps pulling.
    Augusta
    oh ok, well thanks for the info
    I never said that it's gonna be cheap
    i know the o2 flange is different but is the exhaust manifold flange different too?
    Trap'Ville
    i got t25 need rebuild seals gone but still works no shaft play 20bux need it out of my garage i had a sr20 t25 shit still pull hard for a stock turbo got a bigger housing than t28 get a cutom turbo its call big t28 all the internals of a t25 into a t28 shell some shit like that ask famous_attious?? dont think i spelled it right but he sell alot of nissian parts
    Quote Originally Posted by sebastianHoff
    yes, i believe they are very similiar with the exception that the dsm is 90* degrees different than the nissan.
