Results 1 to 2 of 2
Thread: WTT: Type R Head w/GSR cams & GSR Block
    NorthSide
    Default WTT: Type R Head w/GSR cams & GSR Block
    Willing to trade this setup for a stock running Ek +cash. Preferably a Silver EK, but any color will do. Must have Interior intact and no major flaws on vehicle's body/suspension. Needed for a DD. Any more questions just PM me or 95boostedteg.
    B18C1 GSR BLOCK
    81.5mm bore stock sleeves
    Balanced and Blueprinted Bottom End
    Eagle rods
    ACL Bearings
    JE 9.5.1 Forged Pistons
    JE piston rings
    ARP Head Studs
    OEM Head Gasket
    Golden Eagle Oil Sandwich/filter adapter
    Starter
    Endyne Oil Catch Can (crankcase ventilation) (boosted honda motors will LOVE you for this)
    Golden Eagle block guard ( done professionally, bored and honed after install )
    Moroso Oil Pan, already has a bung tapped for oil return line
    Engine will yield appx. 9.8:1 due to the Type R Head
    *B18C5 Type R HEAD (bought head new)
    Ferrea valves
    gsr cams
    Supertech Dual Valve Springs
    Titanium Retainers
    Skunk2 Cam Gears
    timing belt, water pump and oil pump has appx. 5,000 miles on it if that.
    JG Victor X Intake Manifold
    Polished STR 68mm Throttle Body (TPS sensor professionally adjusted by me)
    Throttle cable Bracket
    Distributor has less than 30xxx miles
    Distributor rotor replaced with OEM less than 1,000 miles ago.
    RED AEM Fuel Rail
    Fuel Pressure Gauge
    RED ITR Valve Cover
    It will come with the exedy stage 2 clutch, competition 12.5lb flywheel and the shift linkage.
    will not come with the injectors or spark plug wires.
    DC5-R
    Gwinett
    thats a pretty sweet deal, but I don't think anyone on IA would do that, I would if I had a EK.
