Results 1 to 3 of 3
Thread: B20 BUILD UPDATE! NEW PICS! "OPERATION HYDROLOCK"
    Certified Gearhead SRDFTITAN's Avatar
    Default B20 BUILD UPDATE! NEW PICS! "OPERATION HYDROLOCK"
    Hello everyone, I own a 2001 Acura Integra GSR. Here recently I hydrolocked the engine, and am currently in the process of building a b20 vtec turbo combination. Hopefully I'll be done with the engine by the end of the week, break in and slap on the boost. It was kind of a sad event (my engine hydrolocking, only had 60,000 miles on it). But I guess its forcing me to go in and make some power. I've posted pictures of my car. I've also posted pictures of my GSR motor after it was disassembled (NWS) hide the children, that shit was like a horror movie. And I've also included one pic of the B20 block. I'll have more pics maybe tomorrow after assembly.
    Thanks,
    Ken......open for comments.
    OK JUST CHECK OUT MY PHOTO ALBUM FOR NEW PICS!!!!
    http://photobucket.com/albums/b268/SRDFTITAN/
    I'm getting more pictures very soon but heres a basic list of everything that was purchased for OPERATION HYDROLOCK!!
    Head:
    GSR head w/ fresh mill ( port and polish)
    Dual valve springs
    NEXTGEAR thermal intake manifold gasket
    JG Edelbrock intake manifold
    550cc injectors
    BDL fuel rail
    Aeromotive fpr
    Type R throttle body
    Everything was port matched to each other.
    2 New cam seals
    New valve cover gasket set
    New valve stem seals
    New valve guides
    Valves re-seated
    All valves adjusted and head inspected for optimal operation.
    Block:
    B20B block with fresh hone and deck.
    Eagle rods
    JE pistons
    BDL Block guard
    New Type R oil pump
    New Timing belt
    New Water pump
    B20 Head gasket
    New crank seal
    New rear main seal
    New oil pan gasket
    B20/VTEC oil line kit
    Fresh bearings, rods, mains, and thrust.
    Also little misc. parts:
    Walbro 255lph fuel pump
    Greddy E-01 boost controller
    Apexi turbo timer
    Exedy stage 3 clutch (3 puck sprung)
    Centerforce 7lb flywheel
    MSD Digital Plus ignition
    Blaster coil
    MSD Cap
    Crane cams plug wires
    All new KYB adjustable shocks
    Rear lower tie bar
    Rear upper tie bar
    Rear c-pillar bar
    Rear Triangular bar
    Rear 22mm sway bar
    Front upper tie bar
    And all new Willwood Brakes 11.75" rotor 4 piston caliper.
    And last but now least Apexi N1 muffler (turbo), going to run 3" piping ounce I find a decent turbo kit!!!
    All I need:
    TURBO KIT......
    FUEL MANAGEMENT........
    I will have more pictures up by Thursday or Friday, but my car should be up and running before Friday!!!!
    thanks,
    SRDFTITAN
    ALEX #1Beaver's Avatar
    nice
    Charlotte
    nice man, cant wait for the pics!!
