Results 1 to 4 of 4
Thread: itb for my d series?
    Certified Gearhead htchking's Avatar
    warner robins
    Default itb for my d series?
    i got d series motor and was wondering if n e 1 knew where i can get a kit for itbs?
    Senior Member 99SI's Avatar
    Jackson
    There is some info out there for DIY itb's. Honda Tuning magazine had a tech article about doing them. They used the itb setup from a Suzuki Hyabusa motorcycle and modified them to work. Plan on having a good engine management system in order to get them to work worth a shit. Unless you are planning on building an all out race motor with uber high compression and major lift/duration custom cams I really don't think it would be worth doing. Unless you just want it for the look. For a true performance gain on a D series either boost it or spray it. Good luck
    Daytona Beach
    you wanna buy $1000 - $2000 worth of ITB'S for a d series. :confused:
    doller per hp in that combo is retarded.
    just go direct n20
    dolla per hp in that is 95% better.
    Belview Insane Asylum
    Look around on http://www.ef-honda.com/
    There was a guy that made his own on there, came out pretty kewl too.
