Results 1 to 18 of 18
Thread: sr help part 2.
    stockbridge
    Default sr help part 2.
    so today i drove my car harder than usual..still not hard though like to 6k..
    i came out of work. 4 hrs later. and when i started it up, it almost died after idleing for about 2 seconds, it was goind down to like 300 rpm's.. i had to give it gas to keep it going, then it smoothened out..
    are these things linked? or is it just the cold ect?
    Banned Squidward's Avatar
    Bikini Bottom
    is it still doing it? any other symptoms besides that? how much gas did you have? sounds like a fuel problem if anything judging by that u had to gas it to keep it running. give us more info and u can get more help.
    stockbridge
    still happening? that was the last time i cranked it up, it sounded as if it would idle and shut off, but i didnt allow it.
    i had 1/2 tank of gas..
    no other symptoms..
    It's just a Sentra
    Gwinnett, Georgia
    Quote Originally Posted by Squidward
    Let's see.. Let me get 3 crabby parties.
    "If you want peace, prepare for war"
    It's just a Sentra
    Gwinnett, Georgia
    BTW I would check for boost leaks.
    In the Fucking A
    Check to see if any vac lines have popped off
    I fucked İhris's mom
    i say the mafs connector jiggled loose.
    GTR > My Finger CapnNismo's Avatar
    Macon, GA
    Check your wastegate as well ... maybe that has something to do with it?
    Bikini Bottom
    due to lack of sufficient info we can not dertimine the problem.
    /thread failure
    No0b M0DERATOR auxiliary's Avatar
    woodstock/alpharetta
    either vaccum...or see if the reserc on the bov has come loss, or see if any of the intercooler is off.
    My reserc came off on my stock BOV and I had the same exact thing happen.
    Bikini Bottom
    he doesnt have recirc on that bov. i've seen some pics and it sthe old school HKS BOV.
    i'd check IC piping and any other leaks.
    stockbridge
    Quote Originally Posted by auxiliary
    if intercooler came off, i would not boost, and run rich like mike jones.
    Bikini Bottom
    ^since when did he sell his gold teeth for a turbocharger?
    stockbridge
    i meant RICH. AS IN HE IS RICH, but i would run RICH..
    It's just a Sentra
    Gwinnett, Georgia
    Do a boost leak test to begin with and if that doesn't help call a friend up and swap wires/plugs/distributor/ignitior with him to check that this components are working properly. If tha'ts not it I would do a voltage check on your MAF,TPS and Fuel pump. Sounds like a lot of things to check but you'll be surprised where this little issues come from sometimes.
    All Motor.. For Now
    Sanford, NC
    or u might need sensors. cuase my car did that but i change my front 02 sensor and havent had that probably. but im nto boosted so probably somehting eles for ur car.
    stockbridge
    my o2 sensor is bad, but that is not causing it.
    Under the hood of my car...
    yeah but mike jones wouldnt be in a 240.. he'd rollin in a escalde on 30's.. he's the ice man.. and they call him geroge foreman cause he sellin everyone grillz..
