Results 1 to 5 of 5
Thread: FS-- MSD 6A ignition system
    KING NOOB!!
    Nashville TN-- HELL
    Default FS-- MSD 6A ignition system
    This is an MSD 6A ignition system that will enhance spark and response. I had this on my civic before I wrecked it, but it was bolted in the engine bay safely, and still works like new. Unit will be cleaned before shipping.
    Im asking $125 OBO.
    OPERATING SPECIFICATIONS Operating Voltage: +10-18 VDC Negative GroundCurrent Requirements: 5 Amps-5,000 RPM
    10 Amps-10,000 RPMRPM Range: 15,000 RPM with 14.4 VoltsSpark Duration: 20° Crankshaft RotationEnergy Output Max: 105-115 mJ Per SparkWeight and Size: 2.75 lbs, 8"Lx3.5"Wx2.25"HVoltage Output Max: Primary: 460-480 Volts
    Secondary: 45,000 Volts (Blaster Coil)
    KING NOOB!!
    Nashville TN-- HELL
    bump, its just dirty fella's, it'll clean up.
    PLEASE ban the ricers! JDMshiZnit69's Avatar
    Forsyth, Ga.
    how much of a difference did you notice when you put it on?
    Im wondering if i will see any gain with this.
    i have NGK Irridium IX plugs, and 8.5mm wires already
    KING NOOB!!
    Nashville TN-- HELL
    it still makes a noticable differance, but to get its full potential, you also need to buy a blaster2 coil.
    KING NOOB!!
    Nashville TN-- HELL
    125, ((((((((((OBO))))))))))))
