Thread: 2.5RS Turbo
    Teh rock smoker R3RUN's Avatar
    Atlanta,GA/Tampa,FL
    Default 2.5RS Turbo
    I was wondering if anybody here knows if you could use the turbo setup from a STI on a 98 2.5RS. a friend of mine wants to go turbo and i was just wondering if this was possible and how hard it would be. i just figured this would be a hell of alot less expensive than buying a turbo kit from somewhere.
    A.K.A Felipe Gomez Negrodamus's Avatar
    Daaaaaaknessss
    wouldn't it be a bit easier and "possibly" cheaper to swap in the EJ20t??
    Atlanta,GA/Tampa,FL
    i have no clue thats why im asking.
    Rock the 40oz GTScoob's Avatar
    GA Tech
    Yes you can. All you need to do is get a WRX intake/exhaust manifolds. Those motors cant handle much boost though.
    www.nasioc.com has a lot of good info, just be sure to search first or you'll get your noob-ass flamed.
    02 WRX Sport Wagon
    Atlanta,GA/Tampa,FL
    alright ill check it out. how much boost do you think would be safe on stock internals?
    rockin' the double M's
    l'ville,ga
    8 to 9-ish
    Certified Gearhead jt money's Avatar
    Kennesaw, GA
    personaly if hes trin to save money and not buildd his block before he turbos it i would go with the stock wrx turbo. it should spool very nice on the ej25. just so happens i have one for sale if he needs it pm me.
    it can be cheaper. you do not need the intake manifold just a 90 degree elbow to the inlet. you do need the ex. manifold and uppipe. a wrx crossmember is also required. a downpipe will also be needed. if you are going STi turbo a STi top mount is best. I would not go a pound over 8.
