Results 1 to 23 of 23
Thread: what are the quick mods?
    I plead the 5th burnout1990's Avatar
    FT. Benning
    Default what are the quick mods?
    i was wondering ive done alittle research on unleashing little hp gains in dsm's by doing small stuff like take the honey comb out or balance shaft etc, who knows what all you can do to get all you can ? im runnin a n/a laser right now wanting to see what all motor can do before i boost ( and money) lol im not doing to bad right now i have a gsx head, rs turbo tranny, and i can hang with gsr's through third so i was thinking of doing header maybe or anything else you can suggest besides add a turbo and be done thanks
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    On an NA
    Throttle body, intake mani ported
    Cam (But your a DOHC so you shoudl eba ble to use a mild turbo cam, but i dunno how well it owudl work, prolly hinder you)
    Header, EGR blockoff plate
    Exhaust
    High flow cat
    headwork,
    And by the way, yoru GSX head is the same as yoru NA head minus the cam grind
    FT. Benning
    well the head i bought has like stage 1 cams, alot better than my old one i can hear the intake whistle now, instead of before, plus my old head had bent 9 out of 16 lol
    FT. Benning
    also what should i do with tb? have it bored and matched with the intake?
    GSXTACY SilverJester's Avatar
    Acworth
    You could bore it out or get a mustang TB (like a bbk or whatever other brands are out there) and they will be bigger than you could bore the stock one to.
    saudi arabia
    lol, you can hear the whistle tips like WoooWOOO
    and what brand stage 1 cam?
    FT. Benning
    not sure but they are bigger than my n'a cams that i have, plus yeah it goes wooo wooo lol , but its a noticable difference for sure,
    Certified Gearhead jt money's Avatar
    Kennesaw, GA
    Quote Originally Posted by BuellX1
    nice bubba rub refrence. +1
    Valdosta, GA
    its that woo woo
    FT. Benning
    how do you take the honey comb out of a n/a i dont wanna f up my air sensor
    also the egr block off , will that make the car run funny or what should i do to do it right?
    Jay G. 1439/2000's Avatar
    Location, Location...
    vfaq.com
    Acworth
    you don't want to remove the honeycombs....it'll cause more headaches than anything else. You can back out the screw on the bottom of the mas so that it sits flush with the bottom casing of the mas. The screw is hidden under a rubber or paper cover, can't remeber what it was...but it's a real simple free mod (won't net you much gains though, but I guess every little bit helps).
    saudi arabia
    deff dont remove honeycombs ever
    FT. Benning
    1439/2000 thanks for the link real helpful shit, yeah i didnt want to mess with it but theres a guy i talked to on clubdsm.com has a 13 sec n/t so i know it can be done, just see how money it will take lol, anything else you guys can think of, also where can i buy a header for that car i cant seem to find one....thanks
    Acworth
    have you been to 2gnt.com? I'm sure they will have some useful info for you.
    **edit: n/m I see you have a 1g laser
    FT. Benning
    yeah mines 1g i found a header on ebay but i dont really like it lol, im not going to spend alot of money on shit i wont need after i go boost just wondering, also is there anyway to tighten the shift cables up? i found a few mods to help the play and all but not tighten the cable, im afriad mine might be stretched alittle after 15 years
    Acworth
    I'm not sure if there is a way to tighten them but your cables should be fine it's just that dsm shifters always feel kinda rubbery. You can buy some symbroski (sp?) bushings (only place to get them now is machv.com), or do the free mod which is made of just washers that replace the rubber bushings, but symbroski it is better and only about $20. Machv also sell stiffer bushings that replace the ones where the cables attach to the tranny.
    FT. Benning
    i went to the mitsubishi dealer today and had some things looked at and some good advice from some 1g fans, also instead of making a new thread, did you know that the new eclipse are setup for awd and ins 07 or 08 they will be optional awd pretty damn cool, gonna save up now lol
    Quote Originally Posted by burnout1990
    Did you know that in 07 or 08 they will still be ugly as fuck?
    FT. Benning
    hahaha yeah but its a thought if there anything like a 1g awd (power) and better than a evo then i may just get one, i like to be different , wouldnt it be sweet if they had a twin turbo v-6 awd?? since the new gens are v6's i wonder the stock power they could put out ..... if that happend i wouldnt care about looks lol
    saudi arabia
    your retarded
    FT. Benning
    thank you
    140 on one wheel
    columbus, ga
    your retarded
    LOL
