Thread: Lighting problems....1993 civic.
    Banned anf1tch21's Avatar
    warner robins
    Question Lighting problems....1993 civic.
    sio yeah i have this really small problem which im sure anyone could solve but i am helpless as to how to solve this..i have tried just about everything....so when i turn on my headlights, my tailight goes out...sometimes it will turn on, but then it will go out again..a fuse keeps blowing...i have a breaker in the fuse to keep it from blowing so i keep resetting it instead of changing fuses after fuses....and i have tried to locate the problem for the talight blowing out. the brake light works fine in the daytime and all but the problem arises when i turn on the headlight....any ideas?
    ...so it blows when you touch the brakes but only when the taillights are on?
    warner robins
    no it blows even when i don't press on the brake...
    Quote Originally Posted by anf1tch21
    Most electrical problems trace back to a faulty ground...it's check there.
    warner robins
    where would this faulty ground perhaps be? any ideas where for me to look and check?
    i think a couple of the wires that plug into the back of the bulbs may go to a screw or two somewhere in the chassis...i'd have to see a manual to know for sure though...sometimes the screw needs to be removed, lightly sand the area and the screw, wipe on some dielectric compound, and screw back in...it's a pain if you don't have the interior out though.
    warner robins
    thanks, and yea the interior is already out and i can see all the wires..i'll take a look-see after i finish eating my cinnamon toast crunch cereal
    warner robins
    i looked...no screw to be found anywhere?? couldnt find crap..
    warner robins
    any ideas /suggestions anyone?
    warner robins
    PROBLEM FIXED!! THANKS FOR NOTHING LOL
    west of ATL
    wtf was it???? so anyone else with this prob will know when they read this.
    "You can't spell CrAP without APC"
    4 sale:
    69 mercedeshttp://www.importatlanta.com/forums/...d.php?t=122901
    warner robins
    well i had put a breaker in the fuse, the one that kept blowing so i kept pulling out the bulbs one by one in the tailights, and all the tailights were fine..and i noticed that one light was missing, and that was the corner light and i saw that the bulb wasn't in there and the wires were torn up and it was bare wires, so it was hitting each other, causing a short. problem solved..i just taped it up. word. bump
