Thread: Main bearing/rod journal oil clearance
    Senior Member Code-Aye's Avatar
    hahaha
    Default Main bearing/rod journal oil clearance
    Does anyone know correct oil clearances for a b16a2 with acl bearings? I keep finding different specs
    not sure if my motor was ever line honed before and since im using arp main studs its required
    i found one guy said .018-.020 for all mains/ rods .016-.018 for acl bearings
    or should i go by alldata which says for the b16a2
    Main bearing-to-journal clearance
    No. 1,2,4 and 5 (0.0009-0.0017)
    no. 3 journal (0.0012-0.0019)
    Rod bearing-to-journal oil clearance
    (0.0013-0.0020)
    note i have eagle rods
    the block has previously had all acl std bearings in it, i plan on running acl std's again just need correct spec for them so i can see if the motor has ever been line honed
    what would u run for daily acl race, acl std or honda? which is best for daily driven around 400?
    thanks in advance
    Northwest Georgia
    with acl std, the target is usually around .002
    same with rods....sometimes looser.
    in most cases the arp studs don't distort the main bore...so it may not have ever been bored because it didnt need it.
    hahaha
    Thanks for the info
    hahaha
    For a daily would u run acl race or acl std's
    Northwest Georgia
    acl std DURAGLIDE, not ALUGLIDE
    but Race is fine, they are a little harder and marginally thinner almost un measurably thinner since they dont have the flash coating.
    hahaha
    thanks
