Thread: 94 civic hb kswap
    IA Member urcarislower's Avatar
    Nov 2010
    phenix city
    Default 94 civic hb kswap
    Make: honda
    Model: civic hatchback
    Year: 1994
    Mileage: unknown car title said exempt but the cluster in car said 96k but didn't work
    Options: not many more of a race car lol
    Engine: k24/k20
    Vin#: 2hgeh235xrh512702
    Mods:
    Engine:
    Bottom end is a k24a1 with standrad bore 87mm wiseco 12.5/1 pistons, Manley h beam rods, acl bearings rod&crank, type s oil pump, all balanced with balance sheet.
    Head: is a type-s with supertech vavle/springs/retainers, kelford 179-b cams, rbc intake mani w/ hybrid racing 74mm TB, hybrid racing CAI, hybrid racing fuel rail, rc750 injectors, Arp head studs
    Trans: is a 2009 civic si w/ a comp super single clutch(can upgrade it to a twin if wanted) stock axels 2 sets.
    Engine management: kpro
    Chassis: 94 eg hb w/ tokico blues and ground control coils, traction bars, back half cage, disk brakes all around, bwr RLCA's, carbon fiber hood/mirrors/wing, enkei rpf1s with new tire all around. Might be forgetting a thing or two
    Interior is like barely there underwear lmao a dash some carpet 2 corbeau seats and door trim. No ac/ heater and none of it there if you wanted it.
    Car is currently on a hondata preloaded tune thats similar in compression so it will need further tuning, cranks and runs and you can drive it but its not great i wouldn't try driving it anywhere. Clean and clear title in hand
    Cons: no heat or ac
    Speedometer doesn't work (have a k-tuned converter but don't have a working speedo)
    Body's not flawless (needs painting of the bumpers and tailgate)
    Asking price is 8000obo
    Now on to the pics ( forgive them as its been raining the last couple days and I will get better one once I clean the car up hopefully this weekend)
    Is there something leaking off that bike?.... nope those are just tears....
    Explain the std. bore piston.. you dropped an 87mm piston in there?
    Do you have receipts for machine work?
    And there is no such thing as a "Base Tune" clearly driving the car would only cause problems since A/F, cam timing, ign is W-E-T-F right now...LOL
    Nov 2010
    phenix city
    Yes they are standard bore 87mm pistons and no they weren't just dropped in there, the time was taken to make sure the valve reliefs were put in the proper orientation and the cylinder walls were prep'd
    Yes I have paper work from the machine shop
    Base tune was the wrong wording should of said running a preloaded tune for a similar set that's already on the kpro software
    Sorry for all the confusion
    Edited the points 1civic made thanks guy
    Quote Originally Posted by urcarislower View Post
    Some folks don't know, so never assume that we do..
    Nov 2010
    phenix city
    No reasonable offer overlooked. I have found another car I'd love to have. Someone wants the start of a great all motor street class car. Even has nitrous lines and solenoid that come with car. That's why the bore was left stock.
    Nov 2010
    phenix city
    7k firm! Someone buy it
    Aug 2009
    Default call me asap 6784998297
    Call me asap 6784998297
