Thread: greddy profec b spec 1 help
    Default greddy profec b spec 1 help
    Found a replacement.. thanks
    damn, i want that penis
    Northwest Georgia
    I have an apexi one that would probably work. Same valve configuration. Theres many valves you can use but there is a variance of % as to when each will start controlling boost due to different operating frequencies.
    If yours will work il buy it from you. I need 1 that holds the pressure in the solenoid itself..
    And what sites sell them? Ive been looking all day and couldn't come up with a definite answer to whether there is a replacement spec 1 valve or not
    Northwest Georgia
    i just realized you said spec 1, is it a 2 wire solenoid?
    Yea a 2 wire solenoid.. the 1 that comes with the spec1 is a medium size black box that says greddy on it. The replacement solenoids for the spec2 n typeS will plug up but wont work b/c my head unit doesnt have a vacuum nipple like 8th the newer controllers.. the pressure is held in the solenoid box itself.. my only hope is if dr emmino n dr Brantley can fix mine.. if not ima jus upgrade to mayb a aem truboost or mayn just a typeS to keep it simple
