Thread: Valve adjustment question
    Jul 2009
    Default Valve adjustment question
    Hey IA, need a little input. I have a gsr motor with type r cams installed. My question is should I do my valve lash adjustments based on the cams I'm running or the head they are sitting in? I originally set him to gsr specs and am now questioning that decision. My valvetrain has gotten a bit noisy and want to adjust them again bit want be certain. Sorry for he long post but does anyone think this could contribute to a smoking problem and weird idles?
    Sent from my SGH-T989 using Tapatalk 2
    B18C Valve Adjustment - Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedR.com
    You adjust the valve relative to the cam you are running. Since you are running an OEM camshaft, adjust to Type-R specs. You always run the valve lash that the cam manufacture recommends, which in this case is HONDA
    its 0.006"-0.007" intake and 0.007"-0.008" exhaust. Its best to do them to the tighter clearance. Are you running the dual springs?
    Jul 2009
    Yeah I've got some crower dual valve springs and retainers. Really appreciate the info, I've had them set to gsr specs!!!
    I'd run 0.006 intake and 0.007 Exhaust cold.. Means wake up in the AM and do it!!
    Hes right make sure the motor is stone cold when you set adjustments.
    Jul 2009
    Adjusted the valves and she runs great now. Idles, exhaust, even the intake sounds better. Smoking definately reduced. We'll see what she does in vtec later. Thanks for the great info guys
    Quote Originally Posted by jdmraceboi View Post
    Just keep ear out, hard driving might require a more frequent adjustment.. And since I lean more towards performance, I tend to keep mine on the tighter side..
    I Hope that makes a little sense..
    Mar 2010
    G-Ville
    Tighter valves ya gotta keep checkin the timing belt you snap that you run the risk of bending valves :-/ I learned that the hard way
    Quote Originally Posted by KDMSHARK View Post
    That makes no sense..
    Slow Aeroscout977's Avatar
    Nov 2009
    Lima, OH
    Quote Originally Posted by 1civic View Post
    The effect(Belt snapping) makes perfect sense if you know the real reason behind it's premature failure. (Higher valve spring rating)
    Northwest Georgia
    .001-.002 difference is not going to affect the belt at all. the spring pressure and size of lift are what wear on a belt.
    Nov 2009
    Lima, OH
    ^ Exactly. I was always taught to just follow manufacture specs with adjustments for materials. ie. AL vs CI
