Thread: 96' Civic EX (stock d16y8, 154k miles) "Crank but NO Start"
    IA MEMBER jdm_eg8's Avatar
    Default 96' Civic EX (stock d16y8, 154k miles) "Crank but NO Start"
    Delete
    Car started on 1st try w/o any cranking issues, I just don't get it! Makes it hard to diagnose the problem when its starts up w/o a problem!
    Oops double post
    Feb 2012
    My del sol did this for a while, then took a shit. It ended up being the ecu. Try to get your hands on another ecu and try it out. If it still acts up, you know its not the computer. It will save a lot of headache and $$!!
    Conformer.
    Sounds like ignition coil.
    Emergency Medical Tech
    Oct 2003
    Duluth,Ga
    Have you checked the battery?
    Quote Originally Posted by CDangerfield View Post
    I havent left that out yet but im kinda leading towards it being my ignition coil but am taking everything into consideration because its an intermitting problem, yesterday after i started the car for the 1st time of the day it started right up! But when i started it up the 2nd time it took 3 times for it to start! Then the rest of the day while out christmas shopping with my wife it started w/o any hesitation!
    That's what I'm thinking but I can't test it until it starts acting retarded & not starting can I, that's what sucks....
    Quote Originally Posted by ruah_23 View Post
    I haven't had the battery tested yet but plan on doing it today sometime this afternoon
    Turns out I've got a "Bad Battery". Holds charge & starts the car fine but the crank amps aren't stong enough to crank it at random times!
