Results 1 to 3 of 3
Thread: valve adjustment help
    Oct 2012
    clay co
    Default valve adjustment help
    Anyone in clay co can help me adjust my vavles i got a auto 90 integra gs.
    Certified Gearhead dc5-rsx's Avatar
    Apr 2009
    Atlanta, Ga
    Mitchwerks off 85
    Sent From My Omega Red Galaxy S2
    J.R
    Down South
    Valves should be adjusted cold with cylinder head temperature below 100°F. 1. Position cylinder No. 1 at TDC of compression stroke with UP marks on camshaft pulleys on top and TDC grooves on
    pulley aligning with cylinder head surface. Distributor rotor should also be pointing toward #1 plug wire. 2. Loosen locknuts for #1 intake and exhaust valves and turn
    adjustment screw until feeler gauge slides back and forth with slight amount of drag, then torque intake and exhaust valve locknuts to 18 ft. 3. Rotate crankshaft 180° counterclockwise. The
    up marks on pulley should be at exhaust side and distributor rotor should point toward # 3 plug wire. Check clearance on cylinder # 3 and adjust as in step 2. 4. Rotate crankshaft 180°
    counterclockwise. The UP marks on pulley should be at bottom and distributor rotor should point toward # plug wire. Check clearance on cylinder No. 4 and adjust as in step 2. 5. Rotate
    crankshaft 180° counterclockwise. The UP marks on pulley should be at intake side and distributor rotor should point toward # 2 plug wire. Check clearance of cylinder # 2 and adjust as in step
    2.
    Attached Thumbnails Attached Thumbnails -90integra-valve-1-gif   -90integra-2-gif
