Thread: HELP: 97' Integra LS OEM CD Player Code
    IA MEMBER jdm_eg8's Avatar
    Default HELP: 97' Integra LS OEM CD Player Code
    Okay so I bought a 97' Acura Integra LS all Stock/Unmolested.... Problem is previous owner replaced the Battery & the OEM CD Player now reads err-3 (error code 3).....
    Now from my research about a solution on getting it working again, heres what i found out about what all do I need to obtain the code & is this correct:
    - Serial # off Radio
    - VIN # of the Car
    - Proof of Ownership
    - Then call my local Honda Dealership
    Is that what I've got to do or will the actual code be somewhere on the back of the radio by the Serial #???
    Or if you may know the code I need lmk & I will upload the serial # tomorrow so I can get my radio working again, just lmk IA.
    somewhere, GA
    I have a JVC headunit you can get for $25. Aux port and HD radio ready.
    Problem solved.
    '82 TE72 SR5 Sport Coupe
    3tc
    Quote Originally Posted by D3UC3S View Post
    Problem solved.
    Thanks for the offer but I'm looking to keep this all OEM to hold better value for when I re sell it!
    I know someone knows how to find this out or am I simply right on what to do above?
    pull the deck or look on the bottom of the glove box i believe..only 2 things i know about possibly where it could be
    Acworth
    You are right. Just read off the serial number and honda can tell you the code. Then write it down. i had to do that with one of my civic stock decks.
    Quote Originally Posted by Sammich View Post
    Okay will look at both places when i get home!
    Quote Originally Posted by thepolecat View Post
    Yeah I thought they could do that & tell me but wasn't 100% sure, thanks
    Got it after 1 hour of removing what all I needed to remove to get the Serial #, put it all back together in 30 minutes, called Nalley Acura & got the Code & it works beautiful.... Thanks for the little input IA....
