Thread: 1994 Acura Integra LS Manual Transmission Fluid Change
    Sep 2012
    Default 1994 Acura Integra LS Manual Transmission Fluid Change
    When I change out my cv axles, I plan on putting in new manual transmission fluid and a new magnetic drain plug. My questions:
    1:How much Manual Transmission Fluid does it take to fill up my stock ls tranny?
    2:Where is the drain bolt located?
    3:where do I add the transmission fluid?
    Pictures would be awesome! thanks guys
    somewhere, GA
    1. Buy 3 quarts. You fill it until it pours out of the check hole
    2. Drain bolt is on the bottom of the trans facing the passenger side. Check hole is about 6" above drain bolt.
    3. Pull the speed sensor thats located on the top of the trans under the intake arm.
    4. Google some things homie....
    '82 TE72 SR5 Sport Coupe
    3tc
    Lolol @ wrong section.
    McDonough
    Jackson fails.
    Sent from my Galaxy S3 using Tapatalk.
    Bitches love bacon.
    somewhere, GA
    We all started somewhere
    but yeah...jackson, you completely missed with your thread placement. It would only have been funnier if this was in the kills forum.
    GL with the new axles.
    3tc
    Quote Originally Posted by D3UC3S View Post
    I'm not trying to rip on the dude because he is new, but still, lolol. Maybe someone can move this into the Honda tech section.
