Results 1 to 4 of 4
Thread: Need help wuth integra heating issue
    Jul 2010
    Default Need help wuth integra heating issue
    I think its the cluster but not sure cause I change all the hose and thermostats. Radiator is good, fan blowing good made my own switch to make it run when i start the car. I thought it could be head gasket but i see no water in oil or white smoke or any defect will cause it to over heat I have drive it all the way to the H and no smoke coming out of the hood so my clue is maybe the cluster f**k up or maybe a sensor. Any idea would help me check thank you.
    Dahlonega
    could be a sensor - cheap and easy. but could also be water pump, plugged radiator, or a faulty cluster (least likely).
    are your radiator hoses both hot after driving, or is one hot and the other cold?
    the old man NAIZBST's Avatar
    check your sensors and also the grounds
    RIGGER Sneezin's Avatar
    redtube
    try a new radiator cap and make sure nothing is leaking from around the water pump.
