Results 1 to 16 of 16
Thread: E85 380WHP Super Clean s13 Hatch!! White RPF1s and Screamer pipe!
    notch top s13
    Forsyth
    Default E85 380WHP Super Clean s13 Hatch!! White RPF1s and Screamer pipe!
    Hello Import Atlanta
    This is a feeler thread
    I have no reason for selling other than change.
    Out right buying price $14k
    Mainly looking for trades. I can put cash on top depending on the trade.
    PLEASE NO CLUNKERS or project cars, Running and working cars only please.
    I am also in the market for a legitimate 180sx or any RHD cars that aren’t trash. Preferably no rhd swaps unless detailed documentation is provided.
    Really wanting S2000, Sti, swapped 2.5rs, r32, 180sx, honda beat, or anything AWD or RWD
    Sports cars please not trucks or mini vans !!
    Call or text770 778 3476 for more information.
    I will try my best to answer your questions ASAP
    Here is the link to 70+ detailed photos of the car
    http://s77.photobucket.com/albums/j63/steeledavis/240/#!cpZZ1QQtppZZ36
    Soo let me give you some background on the car,
    I purchased the 119k mile stock 1990 240sx SE shell with everything except a motor and trans in late 2006. The guy I bought it from purchased the car from an old man in southern GA where it had been sitting for a few years after the single cam threw in the towel.
    I spend the next few months preparing the car for the swap. The engine (stock S14 SR20DET) was purchased from NAD Auto in Atlanta GA in Feb 2007. The full swap was done later that month and I was driving the car in early March.
    After running 16lbs of boost with the 2871r for 3 years the engine started getting tired.
    I had always had this fascination with an E85 only SR, soooo I did it.. haha
    Power
    The car Makes 380 Whp and 360wtq or so at 22 lbs of boost with ZERO KNOCK!
    There are 3 settings on the tune that can be toggled through in a matter of seconds.
    -Gate 280whp 12lbs
    -Road race 330whp 16lbs
    -High boost 380whp 22lbs
    here goes all of this is off the top of my head haha
    Electronics
    - all OEM cluster gauges work flawlessly
    -Power FC dejetro (no MAF) MAP sensor
    - Apexi AVCR type r (black face) MAP sensor
    - Innovated Wide band
    - Autometer cobalt boost gauge
    -Autometer cobalt oil pressure gauge
    - Pioneer Head unit
    - (4) Infinity speakers 4x6
    Engine/Drivetrain
    - Fully synthetic oil since the engine build
    ---- S14 VVT SR20DET (5MT) E85 Only tune 380whp 22lbs of boost
    - Everything engine wise was vatted and cleaned by machine shop
    - Honed and slightly bored block
    - CP 10.5-1 high compression pistons
    - Balanced Crank and Rods
    - ARP main bolts
    - ARP head bolts
    - ARP rod Bolts
    - Apexi Metal Head gasket
    - Fully OE rebuilt head 3-angle valve job
    - All seals were replaced with OEM gasket pack
    - New OEM water pump
    - 850cc PE injectors
    - Garrett GT2871r larger hot side with 44mm V-band EWG flange
    - 44mm V-band Tial Black
    - SS turbo lines
    - Custom ram air heat deflecting intake system
    - Tubro XS RFL (really F***ing loud) BOV haha old style
    - Greddy S14 full modded IC piping and core
    - Koyo Radiatior
    - Electric fans with adjustable thermostat control
    - Werker tiny battery
    - Walbro 255 fuel pump
    - New custom ceramic 6 puck clutch /resurfaced fly wheel
    - New Clutch slave
    - New Clutch master
    - Seam welded clutch pedal housing
    - Megan Turbo Elbow (re welded)
    - Flex section Down pipe
    - Japanese full 3” exhaust (custom tucked for ground clearance)
    - Heat wrapped elbow and down pipe
    - Trans has fresh oil
    - KAZZ 1.5way 65% lock setting (grips like a monster with no clunky noise)
    - JDM s13 V-LSD cooling plate pumpkin cover
    - All gaskets replaced and diff was fully vatted and professionally assembled.
    - Authentic NISMO motor mounts
    - Circuit sports poly Trans mount
    - No name Torque dampener
    - Fully gone through cleaned up and rewrapped wiring harness
    Exterior
    - OEM pig nose font lip
    - OEM Mud Flaps
    - OEM rare s13 hatch spoiler.
    - working defrost
    - Pinched and rolled fenders
    - 17x9 +22 Custom White RPF1 (4)
    - 235/40/17 BFG G-force Sports (75% tread remaining)
    - lightly smocked lights all around
    - New super bright halogen head lights silversomething…
    Suspension
    - Corner balanced curb weight with full tank is 2,605lbs
    - JIC FLT-A2 coilovers
    - Tein tension rods
    - no name reinforced RUCAs
    - Tow arms Fully Adjustable (custom built Chromalloy piping)
    - Traction Rods Fully Adjustable (custom built Chromalloy piping)
    - Wicked racing inner/outer tie rod ends
    - New inner tie rod boots
    - Energy suspension Steering rack bushings
    - Circuit sports Subframe collars
    - S14 5 lug conversion
    - S14 spindals (new ball joints)
    - Front strut tower (eBay)
    - Rear upper (eBay)
    Brakes
    -R32 Al 30mm 4 pot front calibers
    - R32 Al Rear 2 pot calipers
    - R32 Internal drum ebrake with newer brake shoes
    - R33 ebrake cables
    - Brembo blank rotors in front
    - Brembo Slotted and drilled rotors in back
    - SLP SS brake conversion lines
    Interior
    - Authentic Bride Zeta III sport with Vios Cushions
    - Authentic Nardi 360mm silver Steering wheel
    - S14 kouki se seats ( still have the pair )
    - Center vent 3 (52mm) gauge pod
    - Dash has 3 small cracks from sitting outside during my last move
    - I have a full rear interior for the car as well.
    - S14 spare tire
    The car is super reliable ! never had any issues with it since the engine build. the engine has around 8k miles on it 2k of which were no boost beak in driven on pump gas.
    The car has a range of about 350 miles to a tank I get on average 24-27mpg on e85 which is amazing considering it is about less 23% less fuel efficient.
    CONS.. there aren't many
    -No AC... but can be hooked up.
    - Must run E85 to boost over 12lbs with new high compression pistons.
    I'm sure there are things I have left out so I will continue to add things as a remember them
    recent pics of the car
    with old wheels
    Thank you looking Have a great day
    6th Gear Junkie Andr3w's Avatar
    Carrollton, GA
    I'm loving the bird finger coming from the bottom of the car lol!
    GLWS
    -2002 Subaru Impreza WRX Wagon
    -2004 Nissan Sentra SE-R Spec V *boosted* (parting out)
    Quote Originally Posted by Nismo062 View Post
    GLWS
    LMAO that and the tire on the block and the fact that the wrench is used on the jack to lift the car #epic super clean man. GLWS
    IA Member chriscote's Avatar
    Nov 2010
    Atlanta / Tuscaloosa AL
    This car is pulls VERY hard and ran amazing. Always been in to s14's but this thing looks incredible in person. Seller is a great guy as well.
    Bump for a very clean 240! Also for a good guy. I bought his rpf1 centercaps, shipped super fast, and was a great deal. GLWTS
    Foot Long Relentless's Avatar
    Snellville
    If I was in the market for a 240 this would be it. GLWS
    The Answer to 1984 is 1776
    -Alex Jones
    somewhere, GA
    Holy shit this is a nice car! Looked amazing with the white enkies.
    '82 TE72 SR5 Sport Coupe
    3tc
    Certified Gearhead bondo's Avatar
    Sep 2008
    sexy, im loving them white rpf1's on the black........glws
    Sig Too Large - IA MGNT & Durty O
    Columbus GA
    very nice car, but you're absolutely out of your mind if you think you're going to get anywhere remotely near 14k for it.
    somewhere, GA
    Im pretty sure he wants a trade. This car is basically show room restored.
    Not hating, but why come in every FS thread like "King Kelly Blue Book"? You gotta just let some things go dude.
    3tc
    Columbus GA
    Quote Originally Posted by D3UC3S View Post
    i understand that, but this car cost almost double what i would pay for it. I see a $7500 car. If this car sold, it would be the most expensive pig nose s13 in the history of humanity.
    Not to mention, this is the 3rd time this car has been listed for sale.....
    first time it was 10k, next time it was like 5500.... now it's 14k...........
    i'm curious to the justification of these price jumps.
    somewhere, GA
    I hear ya, its astronomically high. His parts list is impressive and time and detail spent is commendable so i left it alone. Maybe if he was posting pics of it and at the end said "btw its for sale for 14 k" i would threadjack with a WTF buddy.
    I would usually let you run bc its entertaining but i guess the beer said hey, tell him thats not cool...<3 pignose and skinfix.
    Last edited by D3UC3S; 09-02-2012 at 12:16 AM. Reason: Grammatical shit you fucks pick apart ;)
    3tc
    Nov 2010
    ill trade my awd speed6 for this and your versa. i love this car
    50k miles gt package. fully bolted 315/320 on the stock k04 turbo 93 oct. full suspension and all diff mounts.
    早すぎる TougeGTR-33's Avatar
    You have a pm
    Sent from my DROID3 using Tapatalk 2
    Nov 2010
    North AL
    http://www.importatlanta.com/forums/...s-v6-swap.html
    Interested? The first pic is the most recent as of Sunday. I also have a 93+ lip on the way.
    Interested in a kawasaki 636 motorcycle? Its in amazing condition with low miles and good upgrades?
