Results 1 to 5 of 5
Thread: 99 odyssey transmission problem
    Senior Member EJdm's Avatar
    Default 99 odyssey transmission problem
    recently had a rebuild transmission put in about a year ago and now its having issue but this time its different from before. When its cold the van will drive great with no shifting issues but once the motor get warm up it'll just rev and not go anywhere. Is this a transmission problem again or something else. any feedback is much appreciated.
    "Arriving at one goal is the starting point to another." – John Dewey
    Definitely sounds transmission related, have you checked the fluid level while its running & warm? Does it do it in all ranges (R, D, 123 etc)?
    transmission fluid was flushed out and new fluid was added...all gears does not want to go when hot lol...
    I'd check with who did the rebuild about getting it replaced under warranty. Almost sounds torque converter or front pump related.
    the old man NAIZBST's Avatar
    those transmissions had torque converter problems and fluid pressure problems
