Background information:
1994 civic cx
d16z6 motor, auto p28 ecu
I pulled my d15b7 over the weekend to swap in my rebuilt d16z6. Before I pulled the b7, the AC was working great in the car and would only idle low occasionally. When I was swapping in the z6, we left all of the ac components connected to the car and only moved the ac compressor to the side (held it up with a bungee cord). The AC cools to 40 degrees F when the car is at idle and the fan is working properly. The car no longer has the idle drop when the AC is on.
The Problem:
Although the AC is cooling efficiently, when I attempt to press the gas, the car will stall. If I let go of the gas, the car idles fine again. When the engine was revved with the throttle cable, it would almost die, and then rev up. Also, the compressor did squirt out a little bit of the refrigerant on the floor when the car was revved up. When I turn off the AC, the car has no hesitation moving off from a stop and will not stall at all. My father said that the compressor is locking up, but before I put on the AC belt, the compressor was able to spin freely.
I am looking for any input as to what may be the problem (hoping that the compressor is still good). Is it also possible that it may be a ignition timing issue or that the ac belt is too tight? Thank you for any help in advance!
