Results 1 to 21 of 21
Thread: my z & wifes rx8
    95 civic
    blueridge
    Default my z & wifes rx8
    [IMG][/IMG]
    Senior Citizen Dylan's Avatar
    Milledgeville
    I like the color of the rx8.
    twenty-two
    Family has good taste
    BUILT NOT BOUGHT .........
    Jan 2011
    the rx8 would look so much better with the oem lip
    Senior Member C230K's Avatar
    Feb 2012
    Idk you tell me
    I love the rx8 but, the gas part is horrible
    AFA HOLLYWOOD PREMIER LEAGUE EST. 1998
    95 civic
    blueridge
    yea we got it getting around 20 mpg @212 hp the z gets 34mpg @300hp changed the coils an plugs on the 8 makes it better
    Senior Member sprix!'s Avatar
    I am tempted to call BS on the gas mileage on the Z. Those numbers are obscenely high (34mpg)... even if you do drive highway only. My guess would be that your math is funny, but who knows... you might have some kind of factory freak.
    Yes, that's like 10mpg more than the already generous 24 mpg hwy rating...
    G37s 6MT/coupe
    95 civic
    blueridge
    Default mpg on the z
    ill take a pic of the gauge an post it its says 33 to 34 lol it might be wrong but my gas last along time.
    Columbus GA
    I loved both of these cars.......... until i drove either of them.
    95 civic
    blueridge
    Default pic mpg
    95 civic
    blueridge
    32.5 this morning after drive to work a guy got in front of me an slowed me down causing me to use more gas to go up the hills i try to run 51 to 55 mph in 6th gear @1950/2050 rpms
    yea sinfix i agree love both cars the z not very cozy nice power tho an rides a bit stiff the 8 is more cozy but still little stiff an gas mileage sucks an lack alot of bottom end power think im going to supercharge it tho gas sucks anyhow might as well have some power.
    McDonough
    Gas mileage sucks.
    Let's supercharge it.
    Bitches love bacon.
    95 civic
    blueridge
    agreed lol
    Columbus GA
    Quote Originally Posted by CNH7207 View Post
    First time i got behind the wheel of a 350z my initial reaction was "this feels cheap and revs like a truck" granted, i got out of an s2k to test drive the 350z.
    First time i got behind the wheel of an rx8 my initial reaction was "wow, i cant believe how powerless this car is" I just cant see using an engine that gets the MPG of a big block chevelle but has the torque of a dirt bike........ that burns oil, floods and more times than not, blows up before 100k miles.
    If i had to chose between the 2 cars, id take the rx8 for the platform. Even though i hate the engine, the chassis has a lot of potential.
    Apr 2012
    Cartersville
    Your 350 is 35th aniv edition? If not you're not making 300 hp, either way that's to the crank not the wheels.
    My G35 has the same motor (if you have VQ35DE) and mine makes about 230 to the wheels.
    04 Brilliant Silver G35 Coupe
    95 civic
    blueridge
    aftermarket parts an a tune bro
    Apr 2012
    Cartersville
    Don't put you at 300 unless you have a power adder lol. Well they won't on a G anyways. Bolt ons and a tune give you around 260 on a VQ35DE G, idk if the Z is any different.
    95 civic
    blueridge
    300 at the flywheel not sure whats to the ground just to be clear whats to the ground is a bit less as normal i would think its no to different from the g
    95 civic
    blueridge
    Engine
    2003–2004
    3.5 L (210 cu in) VQ35DE V6 287 bhp (214 kW) 274 lb·ft (371 N·m)
    2005 (35th Anv & Track)
    3.5 L (210 cu in) VQ35DE RevUp V6 300 bhp (220 kW) 260 lb·ft (353 N·m)
    2006
    2007-2009
    3.5 L (210 cu in) VQ35HR V6 306 bhp (228 kW) 268 lb·ft (363 N·m)
    Transmission
    5-Speed RE5R05A automatic
    6-Speed FS6R31A manual
    Wheelbase
    2,649 mm (104.3 in)
    Length
    2003-05: 4,303 mm (169.4 in)
    2006-08: 4,314 mm (169.8 in)
    Width
    1,816 mm (71.5 in)
    Height
    2003-05
    Hatchback: 1,318 mm (51.9 in
    95 civic
    blueridge
    Engine
    3.5 L 190 kW (260 hp) V6
    3.5 L 210 kW (280 hp) V6
    3.5 L 222 kW (298 hp) V6
    Transmission
    5-speed Automatic
    6-speed Manual
    Wheelbase
    2,850 mm (112 in)
    Length
    4,630 mm (182 in)(coupe)
    4,735 mm (186.4 in) (sedan)
    Width
    1,815 mm (71.5 in) (coupe)
    1,750 mm (69 in) (sedan)
    Height
    1,390 mm (55 in) (coupe)
    1,465 mm (57.7 in) (sedan)
    Curb weight
    3,373 lb (1,530 kg) (coupe 6MT)[4]
    3,395 lb (1,540 kg) (coupe 5AT)[4]
    3,395 lb (1,540 kg) (sedan 6MT)
    3,351 lb (1,520 kg) (sedan 5AT)[5]
    3,483 lb (1,580 kg) (sedan CVT-8
    95 civic
    blueridge
    so there is a bit of change depending on the car u have this is the one i got
    2003–2004
