Results 1 to 10 of 10
Thread: rhd conversion
    RISKY RISKYB's Avatar
    athens
    Default rhd conversion
    does anyone know a reputable body shop that can do a rhd conversion and do a good job at it
    DC5-R
    Gwinett
    yeh but its going to run you anywhere between 5-10k for it to be done correctly, a shop name NATI formally known as nirvana located off Old Dixie Hwy. in clayton county.
    athens
    do you have the number
    where do you live ??
    dunno if this will work but a guy is selling a RHD front clip ..
    is there a way that u can take ur dash off urs and use his rhd dash and make some holes and itll be good ??
    dont flame me just was wondering ..
    NY STAY HIGH !!!
    DC5-R
    Gwinett
    Quote Originally Posted by nolimitsteveo
    I think you're talking about making a hole to relocate the steering column or what not, I think it is possible but its a big hassle. RHD conversion are a bit pricey and takes a good amount of time to complete but hey if thats what the man wants then go for it.
    ZERO sir2hb's Avatar
    L.B.C (little bitty calhoun)
    Ok you can get a rhd front clip off hmotorsonline for around 500 bucks, You need to make sure it comes with brake and clutch cylinder and the steering rack
    Other than that all you need is the fire wall and the dash the fender wells and everthing from there up is the same.
    If you get the front clip it can be done for around 2500 to 3000 or at least thats what I would charge to do it thats if you supply the parts. If anyone try to charge you more then that its a rip off.
    I never won any spelling bees
    Horsepower looks good on paper, Torque wins races.
    IA KING
    ya are you doing the motor swap and everything
    athens
    no not swapping the motor, b/c i heard the gsr motors like boost more than the itr (this is still negotiable though) but i wanted to do the rhd swap and then do the itr front end next
    athens
    Quote Originally Posted by RISKYB
    along with 5 lug conversion and then boost
    B20 Vtec HondaCRXVtec's Avatar
    Hi, i live in knoxville and there is this company called Racing Innovations that can get RHD cars for japan for around 6-10k. THE WHOLE CAR. You can get clips and what you have to do is drill out all of the spot welds in the firewall (from the clip and the donor car) then switch them and weld them back together. Then just transfer the motor and everything else. Its not that hard, BUT DO NOT CUT the front end off, that will make your car weak. All you need is the firewall. Racing innovations number is 865-927-7333 if you have any questions. They can also get it registered here in tennessee, maybe in atlanta also i dont know.
