Results 1 to 15 of 15
Thread: fucked headlight question
    revolution big mac's Avatar
    Default fucked headlight question
    car is a 93 si eg. when car is a idle or turned off headlights will work fine. but when car is on and you give it gas they turn off, but turn on as soon as car is back at idle. ive checked alot of thing it could be but im stumped
    Something backwards in the fuse box... LOL
    ive checked just about everything that comes to my mind. shits gay lol
    Ya, My guess would be ether the ELD or bad ground, Need to see What happens tho, meaning does it loose voltage or ground?..
    If the grounds can not support the load then shit can do freeky things.. ELD normally will cause a flicker, but never seen headlights go out under reving..lol thats funny!!
    Best led & Hid Store Raymond's Avatar
    Lawrenceville Georgia
    Quote Originally Posted by big mac View Post
    did you upgrade your car headlight to hid or stock. Seem like your car doesn't have enough power to the light.
    Best regard,
    Raymond!
    GP Thunder Pro HID kits
    Dome Lights-License Plate Lights-Angel Eyes Lights-Signal Lights...
    New DRL fog light in stock now! Please feel free to stop by!
    D1S (made in Korea) - D2R D2S Oem HID Bulbs - D4R D4S Oem Hid Bulbs
    GP Thunder - GOLDEN YELLOW 3500k - Plasma White 7500k - Plasma White with Ion 8500k made in Korea.
    http://www.hidlightsusa.com/
    http://www.importatlanta.com/forums/...play.php?f=228
    its a hid kit. hmmmm but if that were the case wouldnt the kit turn off at idle and on at acceraltion?
    I think he's saying the voltage drops out when reving, and causing them to go out.. Meaning weak batt, weak Alt.. That's what I made of the post anyways
    hmmmm i see what you are saying. i dont think it could be the battery because when key is in on position but with motor off, key stay on no problem.
    Use a Multimeter to check batt voltage with everything on, if it drops below 12 then Alt is not charging good enough.. Try when reving also, you should see 13-13.5 atleast with a good ALT
    buddy just checked it a advanced battery good. alternator running to hot. 18v i think he said would that cause the hid to go into a kind of safty mode?
    Well there you go..
    yup alternator was the culprate unplugging the charge wire off it the hid stay on fine.
    18v is insane, be glad it hasnt done damage..
    yup im taking it off right not and getting a new one in the am
    Dahlonega
    glad you got this solved.
    yeah, the alternator was 17.4v at idle, and 18.9v at 3k with loads on... pretty hot... lol
