Thread: Transmission Slipping ??
    Projects
    Default Transmission Slipping ??
    If an Automatic cars RPMs jump by 200-250rpm when shifting from 2nd to 3rd is this Slipping ?
    LAWRENCEVILLE
    you checked the fluid? how does it look?
    Hella stock member!
    Projects
    Quote Originally Posted by silversol View Post
    When i wipe it on a paper towel it is brown and the level is good but does seem a little watery from feel and look.
    Scottish Scotsman's Avatar
    on the road to recovery
    did you check it while it was running?
    It sounds more like a shift flare. Either way, def check the trans fluid at operating temp with the car running. Sometimes a shift additive can help with this, as can resetting the ECM.
    Emergency Medical Tech
    Oct 2003
    Duluth,Ga
    Brown? Time to replace the fluid and go from there.
    You don't know how STRONG you are until being strong is the only
    CHOICE you have!
    'Born Ready!',LJ
    Projects
    Quote Originally Posted by ruah_23 View Post
    Yeah got a flush done and replaced with Mitsubishi ATF and its great now
