Results 1 to 16 of 16
Thread: 2001 Honda Prelude, No Spark when cold.
    One Curve At A Time
    Default 2001 Honda Prelude, No Spark when cold.
    Car has no spark when its cold outside and therefore won't start. New dizzy, coil, ICM, CPS, CTS, spark plugs, fuel filter, timing belt, water pump. Car began the problem before any of this was started. Problem began after I did a compression test and did not pull the fuses. IF you try long enough the car will start, run like crap for 2-5 minutes then run fine. When its warm out, the car starts perfect.
    97 DX Civic w/ H22 FS
    Yo!
    Oct 2008
    ATLANTA
    Distributor? Hows the firing order?
    One Curve At A Time
    firing order is correct, new distributor. Problem only happens when it is cold outside.
    Senior Citizen Dylan's Avatar
    Milledgeville
    Could be an o2 sensor.
    twenty-two
    Milledgeville
    Is it throwing any CELs?
    twenty-two
    One Curve At A Time
    Only CEL's that come up is from misfire because if you try hard enough you can get it to start, runs like crap, then fine. Other than that? nope. has a new upstream 02 sensor too
    Milledgeville
    Have you checked all the fuses and relays?
    twenty-two
    One Curve At A Time
    yup everything seems good, checking wiring at and near ECU and checking ecu. What has me stumped is the temperature thing. Once it gets close to 70, thing will start and run great
    One Curve At A Time
    well...we put a space heater in the passenger side floor and ran it for 5 mins, the car started right up....smh
    Milledgeville
    Yeah that's usually caused by o2, IAT, CT sensors.. But no cel
    twenty-two
    One Curve At A Time
    leaning toward the ECU now...gonna try warming just that up in the morning....the first 02 sensor, the ct sensor have both been replaced
    Facing what? the ecu? Maybe some brittle solder on the board in the ecu?
    One Curve At A Time
    Yup, facing the dash. We kept thinking the Temp problem was under the hood, but now it seems that it is inside the car...
    if it's stock, see if someone will let you borrow an ecu to try it out. I have 2 that would at least crank it, but I wouldn't drive on it. (F-series ecu's)
    One Curve At A Time
    thats the plan tomorrow. We know a honda-tech that thinks he has one laying around to try. Hopefully that fixes it. Worst part about this thing is we have to let the car get cold before we can try something else. Lol
    One Curve At A Time
    Ecu was the issue
