Car has no spark when its cold outside and therefore won't start. New dizzy, coil, ICM, CPS, CTS, spark plugs, fuel filter, timing belt, water pump. Car began the problem before any of this was started. Problem began after I did a compression test and did not pull the fuses. IF you try long enough the car will start, run like crap for 2-5 minutes then run fine. When its warm out, the car starts perfect.
