Results 1 to 4 of 4
Thread: 96-00 civic alignment issues. (Skunk 2 camber plates)
    2SL0W4U AZN_Pride's Avatar
    Dothan, AL
    Default 96-00 civic alignment issues. (Skunk 2 camber plates)
    I have a set of front S2 Camber plates on my 97 Civic Hatchback. I figured I could get a regular four wheel alignment but I was mistaken. The car is sitting on coilovers right now and I have adjusted the height since the last owner had the car. How can I have the front end aligned with the camber plates? Does A hole have to be cut in the strut towers?
    Luckily I went ahead and went with the lifetime alignment.
    Sep 2008
    Newnan
    I have them on my TL and they can be adjusted on the alignment rack. The tech will simply put a jack under the front end and raise it, possibly remove the wheel and simply make small adjustments to get the camber back to spec. It will take a little more time to do so some alignment places charge extra.
    SOUTHSIDE
    dont cut holes.......the alignment machine allows you to jack up the front to make adjustments.... you just have to pay more... they charge you as a specialty alignment....
    Your mom's bed
    Should of got the pro serires kit and it can be adjusted from the bottom, that's wat I have on my 97 sedan.
