Results 1 to 20 of 20
Thread: need help car wont rev past 3500 rpms
    lil red eg 92sihatch's Avatar
    Jan 2010
    DALTON,GA
    Default need help car wont rev past 3500 rpms
    Need help changed fuel pump now car won't rev past 35k rpms....car is a 2000 gsr
    FIX IT!
    Jan 2010
    DALTON,GA
    Ok that helped a lot....anyone else....
    Jan 2010
    DALTON,GA
    FIX IT!
    Where should I start.....
    Well, if it worked fine until you changed the fuel pump. I would probably re inspect all of your installation to make sure it has been correctly done.
    Or maybe you replaced the fuel pump with a bad one? Later, QD.
    What else did you touch when replacing the fuel pump?
    Jan 2010
    DALTON,GA
    All I dune was disconnect the battery didn't touch anything else besides fuel pump
    Certified Gearhead oreign's Avatar
    May 2011
    check your ecu. once one of the wires on my harness was poking out and it didn't let me rev past 3500.
    Jan 2010
    DALTON,GA
    Quote Originally Posted by oreign View Post
    Didn't touch my ecu but don't hurt to check thanks bro
    May 2011
    disconnecting the battery resets the ecu so it still sounds like an ecu prob lol idk
    Jan 2010
    DALTON,GA
    Disconnected battery ill check it in the mourning.....hope that's it......
    Certified Gearhead jtdb8's Avatar
    Oct 2011
    where everybody knows everybody
    Have You tuned You car? I had had a similar prob. I pulled my ecu for something an I went an put it back in an it wouldn't open up past 4k. I had a non vtec ecu stuck it in an it reved! So I went to the shop an they said it needed dataloging. An that fixed it.
    1-UP!
    Jan 2010
    DALTON,GA
    Stock ecu.....think it might be bad.....car wount start at all......can hear fuel pump start.....
    Jan 2010
    DALTON,GA
    i have a friend coming tomorrow with a jumper harness and a chipped p28........hope it works....
    Oct 2011
    Let me know.
    1-UP!
    Jan 2010
    DALTON,GA
    K thanks
    Jan 2010
    DALTON,GA
    Fixed problem had a bad ecu a friend let me barrow his p72 with jumper.....Hell yeah thanks IA.....
    Oct 2011
    No prob man. Glad to help an see you back up an going.
    1-UP!
    Jan 2010
    DALTON,GA
    Thanks.......
