Results 1 to 15 of 15
Thread: WTB: H22 STUFF!!
    Default WTB: H22 STUFF!!
    I need an aftermarket header, something reasonably priced
    H22 Dizzy, Internal Coil
    H22 or h23 Power Steering pump, brackets and a line
    Certified Gearhead oreign's Avatar
    May 2011
    How about a clutch and pressure plate?
    No, thanks.
    I need a fuel rail as well....
    I have received a PS pump+bracket/line
    The Dark Lude dakilla4ever's Avatar
    In the Darkness
    I may have a dizzy and rail at home. I'll check back with you when I get off work, if you still need it by then.
    Fast+Cheap= Not Reliable
    Cheap+Reliable=Not Fast
    Fast+Reliable=Not Cheap
    THE DARK LUDE SPEAKS
    Senior Member cm7k24's Avatar
    kennesaw
    I have a dizzy, fuel rail,
    Jamal, hit me up. I need both asap.
    And a lower timing cover and an IACV if anyone has those as well.
    McDonough
    The IACV is OBD1 specific isn't it?
    Bitches love bacon.
    Kennesaw, GA
    Got the PS pump and bracket
    Edit. Nevermind.
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    thanks geoff. SIKE
    LAWRENCEVILLE
    I have a brand new iacv, Not sure if its fits the h22 I know if fits civic and integra Non cx and gsr models
    Hella stock member!
    The coolant lines will be 90 degree bends, since it is on front of intake manifold.
    I have a dizzy. I can bring it to you tomorrow
    Kennesaw, GA
    I think I read somewhere that you can use a b16 distributor for internal coil h22s as well. It was either the whole thing or just the internals of it
    OF*C
    I have everything but timing covers. A h22 driver side mount that bolts to the block would be nice as well.
