Results 1 to 20 of 20
Thread: problems with my d17a2
    Jan 2012
    Pulaski
    Default problems with my d17a2
    I think it sparkplugs or vtech goin out once I hit 5k rpm it starts filling like it spitting or vtech kicks in an out just wondering if anybody has had same problem or is it something else I need to check
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    check oil level,vtec screen to see if its clogged if not than remember the car must have its temp sensor functioning at operating temps for oem ecu's,throttle pos sensor, speed sensor, good oil pressure to the vtec pressure switch ect.. for vtec to engage. also you can use a jumper wire from battery to vtec solenoid to her it click off and on. around 5000+ rpm is when vtec should start to take over or it will fall on its face so to speak.
    barrow county
    what is vtech? run on sentences for the win
    LaFayette Ga.
    its a company that makes cordless phones and child learning games! lol.
    Jan 2012
    Pulaski
    Thanks it was oil fill like a idiot.
    barrow county
    what?
    Senior Citizen Dylan's Avatar
    Milledgeville
    what?
    He doesn't perform routine maintenance and almost ran out of oil...that's what happened.
    twenty-two
    Jan 2012
    Pulaski
    When I bought my car I checked everything. They told me oil was changed a 115k miles. But the sticker on the window said it needed to be changed at 110k. So I thought they forgot to change the sticker. So i was gonna drive it to 120k. I checked everything bout two weeks ago and it was all good. So i mean yea I should've just changed it when i got it but It just one those stupid mistakes.
    barrow county
    oil dosnt disappear unless its magical oil.
    your burning oil. oil changed or not, it'll run low if it burns oil.
    Milledgeville
    Quote Originally Posted by Hondaracing View Post
    If it's burning/leaking that much oil in such a short amount of time you have a serious problem.
    twenty-two
    Jan 2012
    Pulaski
    I know. I'm trying to find out what the hell goin on.
    Certified Gearhead YoItsCarlie's Avatar
    Mar 2011
    what year, model and color is your car?
    Milledgeville
    Its an 05 civic ex...maybe purple and gold in color?
    twenty-two
    Jan 2012
    Pulaski
    05 ex. White. Ain't nothing done to it motor wise. But its lowered on skunk 2 springs.
    IA.COM Founder.
    Nov 2000
    Have you checked the Vtec fluid ? If it's low, will cause the engine to burn oil.
    barrow county
    Thats the problem. skunk2 springs make you burn oil.
    you need to swap to skunk2 coil overs.
    Milledgeville
    Quote Originally Posted by Julio View Post
    I would look into this also because the tech fluid can drain into the blinker fluid resivoir. Giving the illusion of low oil levels.
    twenty-two
    IA Member B18slow's Avatar
    Jan 2012
    byron
    Your a dumb ass for not checking your fluids regularly and buying a d series at that
    locust grove
    so harsh on the guy. jeez. not everyone is a gearhead.
    Nothing wrong with d-series engines, but yes you shouldnt make any assumptions on fluid levels especially with a high mileage car
