Results 1 to 13 of 13
Thread: boosted y7 vs b series
    IA Member itr/gsr's Avatar
    Mar 2010
    Grayson
    Default boosted y7 vs b series
    My friend is tryin figure out Wut he should do. Boost his y7 or get a b series? I'm tryin to tell him to get a b series and boosting his y7 is a waste of time and money. While my other friend is tellin him to boost the y7 and it will out run my gsr. O and that it will las longer than a boosted gsr and b series r weak. Which way should he go?
    DD GSR- Obd1 p72, AEM INTAKE, arp head studs, hc head gasket, MSD 6al, 3inch turbo bac EXHAUST, TEST PIPE, GROUND CONTROL COIL OVERS, TOYKICO BLUE HP SHOCKS, TYPE R CONTROL ARMS, JDM front end
    roberta
    personally id go boost,just cause im a boost person...on the other hand depending on the b series could be fun...but i cant figure out why you think it wont keep up with your gsr if it isnt built,youll be surprised how strong a boosted single with a good tune and good parts will move even stock ive seen a z6 on 12psi take a beating for 2 1/2 years completely stock but had a great tune...go boost
    Mar 2010
    Grayson
    Now he's sayin y7 rods can handle 15lbs and pistons 12lbs
    Mar 2010
    Grayson
    Not sayin he shouldn't go boost. It's stock civic he wants to boost.
    Woodstock
    Doesn't matter the engine, I would build the bottom end if going boost... B or D series. The D series rods are VERY weak.....without forged parts you are just rolling the dice.
    As far as one outrunning the other, I'd say a decent boosted D would outrun your bolt on GSR.
    center field
    boost all day on a single ........
    our tuners y7 made 265 hp and 270 tq with just headstuds, for 80,000+ miles. So don't sleep on a y7. Motor still running, we just decided to put a built motor in for some more power.
    http://www.youtube.com/watch?v=hGW8UaZoqGc
    show this clip to your little friend that thinks a b series is weak. It's like everyone is saying here without a tune it run shitty. I own a d series hatch right now and i much rather have my b16 hatch again even though my d series hatch is quick for what it is
    Senior Citizen Dylan's Avatar
    Milledgeville
    Boosted single all day long.
    Senior Member JDMJ's Avatar
    Jun 2009
    Cedar Bluff, Alabama
    Boosted y7 will prob be the cheaper and faster outcome.
    Sig too big
    -IA Management
    Originally Posted by tnomud
    Aren't all IA HOndas 11-12 second cars?
    for a decent turbo set up a d series will cost about the same as a b series, it will be faster than a b-series swap, and it will also beat a bolt on gsr.
    Rome,Ga
    Go boosted d
    Buying a b series motor
    Then mounts
    Shifters
    Axles
    Ecu
    Then hope the motor is good
    Reason i state a d series cause u already have it
    But a new turbo kit or a used name brand kit get it tune
    And pull on b series all day depending there mods
    Boosted D will smoke a stock B series. At least not a junky D
    My line of work
    www.internationaljets.com
